It is currently Wed Aug 13, 2025 1:12 am
PostPosted: Sun Sep 18, 2011 10:19 pm
Are these flat top 998 pistons able to be machined to suit a 1098 build, or is there insufficient crown to the piston?
I know GR pistons are flat top and he does ones to suit 1098, but am just looking at possible alternatives.
PostPosted: Sun Sep 18, 2011 10:24 pm
998 pistons (some) have been shortened in the past to fit 1098s.
I think you will find them a bit thin down to the top ring, after you take 3.75mm off them (1/2 the 7.5mm stroke difference).
Also remember they go down further, so you will have to shorten the skirts.
GR's 1098 ones have the right crown height, but beware they are a bit long- they foul on the dizzy driveshaft unless you thin it down in diameter, or shorten the piston skirts.
[edit] Not sure if this is still the case, but it was an issue last year. Ask Graham...
Last edited by drmini in aust on Mon Sep 19, 2011 8:08 am, edited 1 time in total.
PostPosted: Sun Sep 18, 2011 10:39 pm
How ridiculous is the fact that the pistons he has had made foul the dizzy drive.
That's just madness.
PostPosted: Mon Sep 19, 2011 8:07 am
I put one of his first batch of +100 flat tops in the 1100 - tearing my hair out trying to work out what was wrong but was a simple fix getting the dizzy drive turned down into a little dumbbell
David L
PostPosted: Mon Sep 19, 2011 10:12 am
Supercharged
tell us more about your smallblock willy
PostPosted: Mon Sep 19, 2011 4:44 pm
Soon, soon!
PostPosted: Mon Sep 19, 2011 4:47 pm
I'm excited willy!
The underground movement of small bore lovers is gaining momentum..
PostPosted: Mon Sep 19, 2011 4:56 pm
Mick wrote:
I'm excited willy!
998 love!
You're so square
Baby I don't care
PostPosted: Mon Sep 19, 2011 6:40 pm
hmm lol lol :lol:
PostPosted: Tue Sep 20, 2011 6:43 pm
This engine is going to be built by an SA A-series master, with years of Historic racing experience.
Details to follow.
PostPosted: Tue Sep 20, 2011 8:43 pm
Mick wrote:
I'm excited willy!
And the best ones are a 998 block with a 850 thicktail crank and about 140thou off the top of the block , its almost the same recipe as the European Turbo 850's
PostPosted: Tue Sep 20, 2011 8:53 pm
Supercharged
Details to follow.
I like the sound of that
PostPosted: Tue Sep 20, 2011 8:55 pm
What is this thicktail 850 crank you speak off?
PostPosted: Tue Sep 20, 2011 9:00 pm
Early 850 cranks were only 1-3/8" diameter. Around 1964? they increased it to 1.5" the same as 998 & 1098.
PostPosted: Tue Sep 20, 2011 9:12 pm
:D I can just imagine now all the people out in the shed with the old 850 motor,s that were going to the tip stripping them to measure the crank , just remember you need custom thrusts ( bearings )
Users browsing this forum: Bing [Bot] and 264 guests
