It is currently Thu Aug 14, 2025 9:11 am
PostPosted: Mon Sep 19, 2011 9:14 pm
Buying a rebuildable 1275 will cost extra (but see Mad Matt's for sale adds).
The cost of bearings, gaskets, labour and paint is virtually the same for any standard A series. Go with the 1098 you already have.
PostPosted: Mon Sep 19, 2011 9:43 pm
Thanks for the help guys. I suppose it's gonna depend on how much i can spend and what i can get that's available to me. I will check out the for sale ads as suggested. thanks again guys :)
Regards Kermit (TadPole)
PostPosted: Tue Sep 20, 2011 4:29 pm
A 1275 is also dearer if you don't already have disc brakes.
PostPosted: Tue Sep 20, 2011 5:05 pm
welll,,,, here`s a can of worms opening :-) ;-) :-)
sooooo many of you (nearly all of you) have suggested the 1100,,, here`s my spanner thrown in then
I reckon that if you could afford a 1275 then just do it,,, but yes, you`ll want/need disc to help stop crashing :-)
but,,, in my opinion, the 998 engine is such a smooth little thing, they`re a very very nice little sweet donk,,, you can over-bore them quite a bit, making up the difference in capacity to the 1100,,, but obviously not as much as opening up an 1100 with it`s longer stroke, so still doing the same thing to an 1100 as you would with a 998 won`t make the 998 any better,,, so in the Torque dept, the 1100 wins
but in the reliability dept, i reckon the 998 wins,,, & to give you an idea to mull over-->
i have (in my short life time) pulled apart probably more mini engines than i reckon just about anyone else on this forum & in all that i`ve seen more stuffed 1100 cranks than 998s
soooooo,,,, for longevity/reliability, i`d go for an over-bored 998
but i`m Massively biased towards the 1275 (or more accurately the 1400cc & 1500cc) engines that i`d have to still suggest that if you can afford a 1275 & discs,,,then do it,,, they are stronger, they are MUCH more torque y & are not high maintenance at all when built properly
PostPosted: Tue Sep 20, 2011 5:35 pm
if you get the 1275 and just keep it stock at least you know you got the donk to do it all. SO later on if you want to chase power ... go to town on it.
PostPosted: Tue Sep 20, 2011 5:48 pm
High heel ninja
Im a fan of a 998 with a set of GR's pistons, a good cam & a 12G295 head, theres one on my engine stand at the moment.
I 998 engined car has managed 4th outright at the Hay motorkhana too!!!
Doogie
PostPosted: Tue Sep 20, 2011 8:21 pm
998 for me. Love that smooth high revving engine. Last forever.
060 oversize, mild cam, extractors, 13/4SU. little bit of head work and be very happy.
PostPosted: Tue Sep 20, 2011 8:40 pm
that is definately something to think about. what would a 1275 set me back?
PostPosted: Tue Sep 20, 2011 9:02 pm
Online
A long motor (block/crank/rods/cam/head etc), I'd say ~$500-$1000 for something to rebuild.
Then add about $2K in parts & machining, + labour.
Then add the goodies- carb, manifold, zorst, head work, cam, etc etc.
I'm building a 1365 stroker for a well known member at the moment... 8)
PostPosted: Tue Sep 20, 2011 9:11 pm
what would parts roughly cost me just for the motor rebuild?
PostPosted: Tue Sep 20, 2011 9:16 pm
primary gear & decent ancillarys, decent modified cooling system & dizzy graphed to suit,,, etc etc etc ,,, same principals as any engine build--> you need to sort/design/build a """Package""" no matter which engine you choose
do it wrong & it really doesn`t matter what engine you`ve built,,, do it right tho & you have a beauty that actually is fast & lasts
simple as that
but!!!!!!!!!!!!!!
the design/build,,, no matter what the engine,,, needs to be excecuted around a specific cam choice for the intended application
the correct question "Should be" --> cam choice? .... "That`s" where it all really starts
(or should start anyways)
then design/build it around that
if you can get a 1275 at a reasonable price,,,then why not???
if not, then choose the (then) most 2nd reliable mini engine in the world--> the 998
& work away with that, choosing a cam for your intended application/useage,,, & make sure all the rest of the engine-bits are all suited & all good condition items,,, & all fitted with respect & a knowlege of simple engineering principals & physics
now i`m babbling again,,, babbling into my own can of worms i am :-)
PostPosted: Tue Sep 20, 2011 9:23 pm
oh,,, & now that we`re onto this topic,,, i reckon,,, when i get all my new roofing & new shelving done & all my muster parts & crap is all back into place,,, & the mech-pit is completed & concreated in 7 the wheel alignment rams are moved into their correct place & the new big phat steel beam is fitted into the shed & all these jobs & engines & etcs are all sorted,,, i`m gonna build 2 particular engines
one being a 998,,, fast-road type, still on pump fuel,,, just a std issue mini 5-port,,, that i reckon will blow everyone away
& another job to complete the Bimmer Twinky Conversion,,, --->>>>with the engine still in the car,,, Yep!!!,,, & video that one with my helmet cam
just to be a complete dill
if & when i get the time :-)
anyone keen to sponsor the build of these 2 engines???
PostPosted: Tue Sep 20, 2011 9:31 pm
lol so i should pick the engine then select a cam and go from there?
Users browsing this forum: drmini in aust and 272 guests
