It is currently Sun Aug 03, 2025 3:28 am
 Post subject: Hydrolic Hand Brakes
PostPosted: Wed Sep 21, 2011 9:43 pm
Is there a thread on hydrolic hand brakes & what is needed?
Baracade
PostPosted: Wed Sep 21, 2011 9:47 pm
High heel ninja
You heed a actual handbrake set up & bundy tube, pipe bender.
Doogie
PostPosted: Wed Sep 21, 2011 9:59 pm
lots of threads, but gotta spell it right when you search
"hydraulic"
PostPosted: Wed Sep 21, 2011 10:08 pm
im in accounts...
I work with numbers.. not words...
why doesnt ausmini have a spell check..
it does explain why search never works for me thou thanks simon...
doogie... no idea what your saying to me.
I will go back to dreaming about my soon to be 110 hp a-series... hmmmm numbers again
Baracade
PostPosted: Wed Sep 21, 2011 10:18 pm
Dean, the search function on the forum is absolutely dismal, which is why there are so many multiple threads
:lol:
PostPosted: Wed Sep 21, 2011 10:23 pm
I believe Doogie means you will need something to pull on(handle), which operates a cylinder(the master cylinder for handbrake), which pushes fluid which makes your rear brakes operate. And brake pipes to connect them all together
