It is currently Sun Aug 17, 2025 6:06 am
PostPosted: Fri Sep 23, 2011 10:23 am
Hi all!
As the title suggests, whenever I've got someone in the passenger seat I get this strange ticking noise coming from the front end somewhere. It's the same noise regardless of who is there, so it's not the passenger themselves :P
My ride has also become quite rough, I'm thinking maybe it's time to pay some attention to the suspension? I had the shocks replaced in 2003, not sure about the rubber bits. Everyone complains that a ride in the mini is so bumpy, usually these are people who are used to the smoothness of modern cars. But maybe it shouldn't be as bumpy as it is? And maybe if I replace some suspension bits, the ticking will go?
78 Leyland Mini - Prince
PostPosted: Fri Sep 23, 2011 1:03 pm
New ball joints, knuckle joints, lower arm bushes, tie rod rubbers and inspect the top arm pin and bearings definitely aren't going to hurt!
PostPosted: Fri Sep 23, 2011 1:13 pm
Only ia a straight line Dyl, or when steering is turned too ?
PostPosted: Fri Sep 23, 2011 1:49 pm
A consistent tch, tch, tch?
PostPosted: Fri Sep 23, 2011 1:55 pm
Is the noise a whine, whinge nag or scream?
- Simon -
PostPosted: Fri Sep 23, 2011 2:05 pm
Thats very strange, i have these noises whenever my wife is in the passenger seat :shock: , and even stranger, it doesnt matter which car we are in either.....
PostPosted: Fri Sep 23, 2011 5:19 pm
I had a similar issue with our toyota hilux. Whenever there was a passenger, it would 'click' when entering a corner and 'click' when leaving the corner.
Turned out one of the bolts holding the front of the seat down was loose. Worth a look anyway.
PostPosted: Fri Sep 23, 2011 9:43 pm
Rover Cooper
its the ****%ing minister of finaance
PostPosted: Wed Oct 05, 2011 9:44 am
It's not the minister of finance :lol: it does it when she's not in the car too...
I noticed that the noise is there when i was by myself the other day too (but only at 90-100km/h), it is just more pronounced when someone is riding shotgun.
Replaced front bearings about 12-18 months ago, so that's not it.
Seems to be a constant noise, eases o a bit with a slight turn of the wheel. When a passenger is present it is more pronounced upon acceleration.
PostPosted: Wed Oct 05, 2011 11:21 am
Have you actually taken the wheeh off for a look yet to check and rule out the obvious?
Just cause the wheel bearings were replaced 12 months ago doesn't mean they might not be knackered. Check ball joints, these are important, and with the wheel on full lock and the car in neutral rotate the driveshafts to see if something sounds off like a CV or something.
PostPosted: Thu Oct 06, 2011 1:50 pm
Haha no I didn't even look... perhaps that should have been the first step! :lol:
I've taken the car back to mum and dad's place for it to live, I'll have to get down there and have a squizz with Rodney
Users browsing this forum: Bing [Bot] and 324 guests
