It is currently Tue Jul 29, 2025 2:07 pm
 Post subject: More SPI questions
PostPosted: Sun Sep 25, 2011 8:24 pm
Can anyone tell me what type of car this ECU is out of...
Has 94 auto written on but sure someone said that the part number was the teller MNE 10026 1742 4022
Also what engine detail is this
12A20J333352
thanks guys
PostPosted: Sun Sep 25, 2011 9:04 pm
Reference the engine number have a look here
http://www.guess-works.com/Tech/engine.htm
Cheers Pete
PostPosted: Sun Sep 25, 2011 9:39 pm
If its a mini computer and says 94 auto thats all you need to know.
All the autos ran the same compression so there's no difference between them, unlike manuals where there were high and low compression engines (though I'll bet the computer is still the same).
PostPosted: Sun Sep 25, 2011 9:46 pm
Well the thing is I have a stick thingo in the car... Has positions 1,2,3,4 and R....
The only automatic thing about it is me changing them!
Lol
 Post subject: SPI INFORMATION
PostPosted: Mon Sep 26, 2011 8:13 am
All the information about rover mini's 1969 to 2001
can be found in the;
Haynes service and repair manual 0646
Available from the pitstop book shop in perth
email [email protected]
cost is about $67-00
 Post subject: Re: SPI INFORMATION
PostPosted: Wed Sep 28, 2011 3:38 pm
Or check here...........................
http://mini.nicehelp.co.uk/
PostPosted: Wed Sep 28, 2011 4:52 pm
Or with free postage from UK - $33
http://www.bookdepository.co.uk/13th-Re ... 1859609231
PostPosted: Fri Sep 30, 2011 12:59 pm
Also can u convert a two plug loom to a one plug?
PostPosted: Fri Sep 30, 2011 1:02 pm
You probably can, though it's not something I'd try myself.
You can't buy converters to my knowledge either.
PostPosted: Fri Sep 30, 2011 1:32 pm
I only ask as alot of the aftermarket ecu's are single plug and they say its easy to convert its just a wire from the 2nd plug soldered onto a wire on main plug! 2nd pluv is oxy sensor... So wonder if u can on original ecu?
PostPosted: Fri Sep 30, 2011 1:37 pm
Probably easier than you'd think, I know my computer has the 2 plugs, a 50 pin and a 30 pin, only 1 wire on the 30 pin is used: it goes to one side of the coil pack.
It's such a stupid thing, I don't know why they bother.
PostPosted: Fri Sep 30, 2011 3:27 pm
Mmm... I may call specialist components and see if they have a clue....
Anyone here have a clue? Lol
