It is currently Sat Jul 26, 2025 10:22 pm
 Post subject: 25D Vs 45D Distributor
PostPosted: Tue Sep 27, 2011 7:25 pm
Hi,
My A series 1275cc has a 25D distibutor with the vacuum blocked off due to the twin carbs.
I think my dissy is playing up and i am thinking of replacing it, is it worth sourcing a non-vac distributor or is it okay to block off the vac on a new unit.
P.S. Is there any difference between a 25D & 45D distributor?
Thanks
Roc
PostPosted: Tue Sep 27, 2011 7:34 pm
Non-vac 45Ds (actually called 43Ds) were used on Minis 1975-1978. Plenty about and they are a good robust dizzy. Even better if you toss the points and fit an electronic module (Pertronix etc) in them. :wink:
I used one for years in my modified 1310S.
PostPosted: Tue Sep 27, 2011 8:11 pm
Depending on the type of carb there's no reason to forego a vac advance because you have twins. And without it you're throwing away $$$.
Cheers, Ian
PostPosted: Tue Sep 27, 2011 8:20 pm
Try the Nissan Pulsar dizzy, no points to worry about, I have had one for over two years and no problems
Kochie 8)
PostPosted: Tue Sep 27, 2011 8:23 pm
Kochie 8)
I run a Pulsar in the 1360 and another in the 1412 stroker.
Yes they work well, but even better if you get the advance curve modified.
PostPosted: Tue Sep 27, 2011 8:27 pm
do you have to take it somewhere special to get the advance curve modified
PostPosted: Tue Sep 27, 2011 8:29 pm
Graham Russell does them.
Russell Engineering
113 North Rocks Rd
North Rocks 2151
(02) 9630 2195
PostPosted: Tue Sep 27, 2011 9:18 pm
cheers, i just bought one. but thats far a far away. i;ll let read speed have some fun with it. i'm sure he'll carve it up. :D
PostPosted: Tue Sep 27, 2011 9:57 pm
Reduce the centrifugal advance slot lengths to give about 10° max.
See my how-to at top of mods forum. :wink:
PostPosted: Tue Sep 27, 2011 10:39 pm
will do thanks
