It is currently Fri Jul 18, 2025 1:49 pm
 Post subject: A stubborn outer race
PostPosted: Tue Jun 22, 2004 9:44 pm
One of the outer races of the wheel bearings in my hubs will not move........every BFH ive tried wont make it move. Theres massive chunks missing from my drift as a result of the sucker too.
Ive been applying WD40 to try lube it up aswell but nothing is working :(
any suggestions?
[Maverick] 1971 Mini K
PostPosted: Tue Jun 22, 2004 10:24 pm
if ya can get one of those hot air guns, heat the surrounding metal.
If you're using a soft drift, get a harder one. I find a good solid steel punch works well(I used a ratchet extension, BODGY). just make sure the hub is supported firmly on some blocks of wood etc.
"He's always been a dickhead, He always is a dickhead, He will always be a dickhead. So stop complaining when he acts like one."
PostPosted: Tue Jun 22, 2004 10:28 pm
I use a small cold chisel with the sharp bit ground flat. And a BFH..
Never hit them except in the slots provided in the inner web. You can easily burr and stuff up the web in the hub if not careful.
PostPosted: Tue Jun 22, 2004 11:18 pm
i might try heating the hub and see how i go.....
PostPosted: Wed Jun 23, 2004 7:06 am
Oxy or LPG torch is more effective for this than a hot air gun...! :P
<edit> is it a disc or drum swivel hub? If it's drum just get another- everyone has bins full of 'em.. :wink:
PostPosted: Wed Jun 23, 2004 10:43 am
Its a disc swivel hub......ill give heating it a try today and see how i go!
PostPosted: Wed Jun 23, 2004 11:27 am
Hmmmm, I thinks my hot air gun works well. If its hot enough to be scorching paint off its enough to be breaking any corrosion up under the bearing race. And nowhere near the chance of overheating the metal as Oxy or Butane Torch.
Users browsing this forum: 1071 S and 106 guests
