It is currently Wed Jul 23, 2025 11:45 am
 Post subject: Heater??
PostPosted: Mon Apr 18, 2005 8:34 pm
Hey Guys
I have Just found that my heater has been disconected by the previouse owner would there be any reason for this?
some one told me it could be that it is leaking or it is cracked or something could any one tell me what it could be.
and any one know of a price of a new one is or what ever new old whatever one that works.
Thanks
Blackrz
(998cc Clubman)
- = :Zone 3 Goober: = -
http://photobucket.com/albums/y142/blackrz/?sc=1
"I Live My Life A Quater Mile At A Time"
PostPosted: Mon Apr 18, 2005 8:41 pm
Probably the vavlve that needs replacing. You can buy these new, and i dont think that they cost that much. They always seize up and sometimes leak, so its worth replacing!
PostPosted: Mon Apr 18, 2005 8:47 pm
Sometimes the heater is disconnected because one of the hoses has split. It may also be a leaking heater core or valve. Just pull the heater box out and check the core and clean the box out while you are there, flush the core out and fit some new hoses and you are ready for winter.
PostPosted: Mon Apr 18, 2005 8:53 pm
Do it, the valves often sieze up. i know mine has!
but BEWARE, heaters are absolute **** to put back together. well, mine was when we had to put in in for RWC
78 Leyland Mini - Prince
PostPosted: Mon Apr 18, 2005 11:00 pm
I cut and welded the brackets to raise the heater up under the dash more (out of sight) but I have decided that I'm not putting one back in JAM...I hate the look of clubby heaters! :x
So I have 2 if anyone needs one.
PostPosted: Tue Apr 19, 2005 7:17 am
On our Clubbie I just flung the POS valve and put the hose back on. :wink:
You want cool air, open the bloody quarter vents.. :P
PostPosted: Tue Apr 19, 2005 7:30 am
Until they break :(
PostPosted: Tue Apr 19, 2005 7:53 am
Both my current minis require many layers of clothing in the winter. No heaters included!
PostPosted: Tue Apr 19, 2005 7:54 am
Mine doesn't...it get's quite hot inside, with all the heat from the exhaust running down the firewall and underneath the car :)
PostPosted: Tue Apr 19, 2005 8:18 am
Can I take my heater core and use it as an extra rad under the hood? Maybe mount it where an oil cooler is fitted?!? What do you think?
PostPosted: Tue Apr 19, 2005 11:17 am
JAM, that would be fine, just a pita to route all piping I would assume.
PostPosted: Tue Apr 19, 2005 11:54 am
maybe a PITA...but surely it's just the rubber hoses that would normally feed into the cabin. And on that subject....how many Mini's leak from that point where the hoses enter the cabin! :x I know JAM did, and Pops does!!!
PostPosted: Tue Apr 19, 2005 2:08 pm
I wouldn't bother Anton, you will just make the engine bay look cluttered and if the rad is good and the engine build is good, it won't overheat. Keep it simple i say! 8)
Aaron
PostPosted: Tue Apr 19, 2005 3:48 pm
BlackRZ, mine was seized also, the valve was one big chunk of corrosion.
If you still have a heater in the car its more than likely just the valve and some hose that needs replacing. I pulled my entire heater system out, cleaned all the crap, replaced the valve with a Universal Holden/Ford valve and put it all back together, reconnected the hoses to the right place, now it all works perfectly.
The levers to the dash and valve prolly need some CRC assisted TLC, but if you're lucky they'll work again.
Note though that the Holden/Ford valve has bigger diameter inlet and outlet, but I put my hoses in really hot water and pushed like hell.. they fit ;)
www.crazybitchracing.com
PostPosted: Tue Apr 19, 2005 7:25 pm
Piece of cake. Just mount the core behind the grille and shorten the hoses.
:idea: Or fit a $50 MiniMatic heater, then you can have heat in the car and extra rad cooling!
As Aaron says though the extra cooling is hardly needed, unless you have a crap hot (big) motor.. :P
Users browsing this forum: winabbey and 92 guests
