It is currently Sun Aug 17, 2025 6:00 am
PostPosted: Sat Oct 08, 2011 8:46 am
BALLISTIC wrote:
Im guessing that you have the fluid pressure switch on the drivers side of the subframe, if you want to check your brakes lights and the circuit are ok . . . plug an on/off switch into the wires and operate manually, if brake lights work your brake light switch has an "open circuit" or is at fault and requires replacing.
I bought a few of these hydraulic brake switches recently, I dunno where made now (not Lockheed) but they are crap. I got 3 months out of 1 and 3 weeks out of another. Lengthen the 2 wires and fit a Clubby switch to the brake pedal box if you want a reliable switch. :wink:
PostPosted: Sat Oct 08, 2011 2:55 pm
Thats what I did :D
PostPosted: Sat Oct 08, 2011 5:06 pm
I got a new pressure switch from Karcraft a few years ago and it is working fine.
PostPosted: Sat Oct 08, 2011 7:39 pm
Probably it was made closer to London than Beijing then. :lol:
PostPosted: Sat Oct 08, 2011 7:50 pm
Sometimes it is cheaper to spend more in the first place.
PostPosted: Sat Oct 08, 2011 8:39 pm
ok fellas got it all fixed indicaxtors just decided to start workin which was good :) also my brakes just was the sender unit not workin so replaced that and all fixed cheers by the way i got a mini aka my brother that was my thought in the first place no need to post 3 times :) cheers
1964 smooth roof panel van
1967 Mk 1 X-Police cooper s
1970 mini k
1975 leyland
PostPosted: Sat Oct 08, 2011 9:19 pm
If they just started working on their own it was possibly a voltage problem that sorted its self out when the battery charged up.
PostPosted: Sat Oct 08, 2011 10:38 pm
yeah that's what I'm thinking. I knew it! I was right hehe :P Quite common for this to happen.
Users browsing this forum: No registered users and 325 guests
