It is currently Sun Jul 27, 2025 8:46 pm
PostPosted: Sun Oct 23, 2011 5:13 pm
Hi, trying to work out if i have put this together right?
im not sure where the centre spring goes, atm i have it connected to the accelerator clamp
and if the linkages are the right way
sorry pics aren't the best laptop camera
1971 mk2 police cooper s
1988 rover mayfair modified!!
PostPosted: Sun Oct 23, 2011 5:17 pm
There is normally a little tag that the spring attaches to.
The tag sits where you have the spring. I will see if I can find a photo or something...
PostPosted: Sun Oct 23, 2011 5:19 pm
but the accelerator clamp still goes through that hole? and the tag attaches to the clamp?
PostPosted: Sun Oct 23, 2011 5:32 pm
Actually you have the wrong cable bolt. Yours is a choke cable one not a throttle one.
This is the correct one and it shows the spring link (AUD3152)
It goes in the same place and it has a split pin in the end of it.
PostPosted: Sun Oct 23, 2011 5:34 pm
thanks morris 1100,
ill have a look in the spare parts bin
