It is currently Wed Jul 23, 2025 1:36 am
 Post subject: Clubman Reverse lights
PostPosted: Tue Apr 19, 2005 9:29 pm
I was wonderin if a 74, 1100 clubbie rod change has reverse lights. I know there are wires goin to the selectors but mine arnt connected up at the moment and they wernt connected when I bought it.
Mini Clubman, 1.3i, air con, 12" mags, pioneer sound system.
PostPosted: Tue Apr 19, 2005 9:34 pm
i thought all clubmans had reversing light but it was just the blinkers that came on.
PostPosted: Tue Apr 19, 2005 9:37 pm
Yes, all Clubbies have twin filament rear blinker bulbs. Wiring on remote shift (early ) gearboxes was from a switch in front of box (below oil filter)- on rod change boxes the switch is in the shifter box, near the gearlever.
PostPosted: Tue Apr 19, 2005 10:05 pm
my reversing lights havent ever worked worked, i have a remote gearbox and there is two wires that go two nowhere near the remote bit, my car used to have a rod change so maybe they went into that, so where are they ment to go
PostPosted: Tue Apr 19, 2005 10:20 pm
On early cars they are up the front behind the grille. When I put a rod change box into one I had to run the wires along the subframe to get to the reverse switch.
On the later rodchange cars (I've got one) I can't remember how the wires get to the switch near the gearstick.
The wire colours you are looking for are green, and green/black. :wink:
BTW I've just found most wiring diagrams here for Clubbie are BS, including the ones in the official Leyland `Black Book'. Just crappy reprints of UK Mini wiring.. all wrong for ours! :x
PostPosted: Wed Apr 20, 2005 8:47 am
JAM was a 100% original clubby when I got it, and that is how the reverse wiring was. It's a 76 model.
The wire to the box comes from the loom just behind the front bumper. It's a long dual wire.....it goes under the subframe and is very susceptible to damage. Check that out.
PostPosted: Wed Apr 20, 2005 9:47 am
NAV-MAN
Yep i know about that, my wires were exposed by a low flying object and were shorting on the chassis and i couln't work out where the short was unit the car kept blowing fuses everytime i put it into reverse so i found it that way. I still have to replace the wires as i just disconnected it :oops:
PostPosted: Wed Apr 20, 2005 11:02 am
ahh the dreadED clubbie reverse lights, i had no idea i even had them, i put the car in for a roadworthy and the tester put it on the fail list, then i argued with him that clubbies didnt have them so he crossed it off the list hehe, then i came on here and was told otherwise haha!! mine are now hooked up and working a treat!!
