It is currently Sat Jul 19, 2025 11:00 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: What's going on????
PostPosted: Sat Nov 05, 2011 5:12 pm
Finally registered and on the road and trying to put a few K's (miles) on it.
Have or had three issues.
1. After the fist 50K trip on retrurn I found that there was coolant weaping out from the head gasket. Torqued it back down (60Newtons). Second run still a slight weap of coolant. Third, long run and appears to have stopped. What's going on??
2. The cover plates over the push rods, fitted with cork caskets and good sealant were leaking oil down the back of the engine. I had them a nice snug tight, but obviously not tight enough. Can you tighten the bejessus out of those cork gaskets??????
3. With the engine at running temp and sitting there idling, there is a slight "clack clack'' noise coming from the engine area. When you push the clutch pedal in it completely goes. What could that be????
Dalmeny
 Post subject: Re: What's going on????
PostPosted: Sat Nov 05, 2011 5:18 pm
1. what sort of gasket?
2. I think the rubber ones work better, but haven't had side covers for years
3. what is your idler gear thrust washer clearance and primary gear bush clearance like? what condition is your thrust bearing in?
PostPosted: Sat Nov 05, 2011 6:19 pm
1. Not a copper one. Can't remember the brand, but one of those composite types.
3. Clutch and pressure plate new. Idle gear thrust washer, don't know. Primary gear bush, no lateral movement.
Dalmeny
PostPosted: Sat Nov 05, 2011 6:37 pm
Very neat engine bay. 8)
PostPosted: Sat Nov 05, 2011 7:39 pm
3a. does your clack clack stay there if you hold the revs at (say) 2K rpm?
3b. the workshop manual describes setting the idler gear clearance which should always be done when putting an engine & gearbox together. Too tight and the thrust washers bind up against the transfer case and make a mess, too loose and the idler gear will slip from side to side under pulsation from the crank. Putting the engine under load (revving) or putting your foot on the clutch (disengaging) could be attributed to stopping the noise. Same could be coming from the primary gear if the clearances are too big.
3c. is it a 'hot' cam? I've heard (read) Dr Mini say that 1275's with a hot cam make that sort of a noise at idle - as mine always have done - though it seems to come from the front of the motor (cam gears etc.). Dunno if little motors do it too.
3d. Maybe the noise could be from the oil pump as well - new oil pump? what's your timing gear like? new gears and chain?
any clack clack sort of noises down that end of the motor will echo around because there's a lot of alloy in there. Could be all sorts of things, I may be talking out of my arse too - ultimately you're the only one who can diagnose and correct it because you're the one with the car
PostPosted: Sat Nov 05, 2011 8:34 pm
Thanks Simon
New oil pump, new duplex timing chain and gears and mild cam.
Anyone else got an opinion? Is it possible for the idle gear to slide back and forth a few thou and make a clack clack noise?
Dalmeny
PostPosted: Sat Nov 05, 2011 9:48 pm
how long was youre rebuild abs fab engine layout m8 was it complete nut and bolt wat is the paint color nice....
PostPosted: Sat Nov 05, 2011 10:12 pm
Dude, its a MINI, all of the above are normal :lol:
Master of the Moggie Army & Founder of Awesomestock2010
my rear covers both are leaking too, clean and new rubber and nut done up enough to squash in the cover a bit, looks like i will need silicon as well
if ur engine is new and using thin cheap oil it may sound a bit rattly in the tappets too, did u adjust the rockers?
PostPosted: Sat Nov 05, 2011 10:14 pm
See, totally normal :wink:
PostPosted: Sat Nov 05, 2011 10:44 pm
See members gallery "Clubman Project"
Dalmeny
PostPosted: Sat Nov 05, 2011 10:48 pm
If it was tappets I don't think it would go away pushing the clutch in.
Dalmeny
PostPosted: Sat Nov 05, 2011 11:21 pm
I can see there that you are not running any breathers , I am suspecting a crankcase pressure problem , as the pressure expands it will try to find the weak spots , gaskets etc
my 2c
PostPosted: Sat Nov 05, 2011 11:24 pm
i know that , just givn u some heads up for when u get rid of that noise what u will hear next.
PostPosted: Sun Nov 06, 2011 7:22 am
If your covers are the ones that rise outwards with the bolt on the peak then you need to seal around the bolt head. There is a rubber/felt washer as new but I put some RTV Grey gasket maker under the bolt head and the leak stopped.
Agree also with the suggestion that unless the engine breathing is set up properly it will blow oil. Can't see a PCV set up in that rocker cover. I have the same cover that I put a BSB thread and 90 degree angle output and plumbed it in with a toyota PCV (under advice from DrMini) to the manifold.
Dave K.
