It is currently Sat Jul 19, 2025 2:08 am
 Post subject: best battery
PostPosted: Mon Nov 07, 2011 8:01 pm
what do you guys reccomend for battery.
i drive my mini once a month and find the battery always die's.
Am I better off buying a deep cycle battery or stick to conventional..
Are there batteries made for cars that sit in the garage for long period of time??
PostPosted: Mon Nov 07, 2011 8:17 pm
Once a month hmm dunno what type if I'm not driving mine for a while I disconnect it.
PostPosted: Mon Nov 07, 2011 8:21 pm
Optima red top :) , you may pay more up front but you get more in return
PostPosted: Mon Nov 07, 2011 8:46 pm
http://www.extremebatteries.com.au/a/Fu ... _batteries
I have had a Full river battery for a year now . leave the car for 4 - 6 weeks sometimes, still cranks like new. I have a good alternator also.
Rod at Extreme Batteries knows his stuff.
Now with 2 extra ports!
PostPosted: Mon Nov 07, 2011 9:51 pm
AGM (absorbed glass matt) are low discharge and work well in this situation. The downside is you may not get massive cold cranking amps in that style of battery.
I have an AGM battery in my motorbike and it works well with little use. I've also heard good things about Optima's but never tried one.
PostPosted: Mon Nov 07, 2011 10:00 pm
Buy the biggest CCA battery you can fit into your battery box. I have a 550CCA Bosch from supercheap. I drove my car 7 or 8 times in total since Oct last year, no battery problems.
PostPosted: Mon Nov 07, 2011 11:40 pm
Tomboss Breweros
Like Lillee i have big cca batteries, the reserve capacity is important too, bigger is better.
Lead acid batteries hate going dead flat, they won't come back to 100% of how they were before going flat.
Test the car for static current draw, should be less than 0.05A.
Otherwise, for any car that sits for a long time i strongly reccomend a good quality maintenance charger that cuts out once the battery is at float volts.
C-tec is very good, the one below won't be very good to charge a flat battery (only 800mA) but it will keep a good battery alive and well.
I have one like this, 3600mA and a couple more functions.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Nov 08, 2011 8:15 am
I bought an Optima red top recently and the doco with it is a bit vague about whether a normal trickle charger is safe to use. In the end I replaced the one I had with a Ctek 800.
66 Deluxe, 07 Cooper
PostPosted: Tue Nov 08, 2011 11:59 am
I had an Optima Yellow Top in various cars & ended out doing duty in the mini. It died after 7 years, so pretty happy with that. Not cheap to replace though.
You should only use a charger suitable for AGM batteries if you want them to last.
PostPosted: Tue Nov 08, 2011 5:14 pm
Exide " EX56D " $ 168.00 from Big W , 550cca ( cold cranking amps ) , plenty big enough , I have three of them , i run one in my mini , my Turbo Diesel Rodeo and an XR 6 Falcon.
They fit in the mini just right and i can swap them from each car if need be.
PostPosted: Tue Nov 08, 2011 5:46 pm
Red Optima.
My cars are lazy good fernuttin' layabouts. I need something that will hold a charge over an extended period while the cars lounge about in the garage doin' f'all.
Oh, and I have the cTek charger. Good fer me Ducati's as well.
 Post subject: battery
PostPosted: Tue Nov 08, 2011 8:09 pm
nice nice and nice..
turned out a great thread..
i got a preice on optima RED top for $280 today..
thinking i might go down that path.. then again i can get a really good deal on bosch batteries.. missus works for siemens whom own bosch....
hmmmm decisions decisions..
 Post subject: Re: battery
PostPosted: Wed Nov 09, 2011 5:02 am
Well, that make it easy , Optima for the garage car and Bosch for the regular use/ daily driver
PostPosted: Wed Nov 09, 2011 7:27 am
hey snail... have you got a 7 port head on yours???
I may be wrong but I thought you were on another thread talking about installing a 7 port head. How did it go and whats the power like?
PostPosted: Wed Nov 09, 2011 11:51 am
Oh yes yellow top all the way great battery and light as well!
