It is currently Sun Aug 10, 2025 2:41 am
 Post subject: mk 2 cooper s alternator
PostPosted: Sat Nov 12, 2011 2:24 pm
Hi All,Does anyone have a wiring diagram for this alternator which also shows internals.
I know it has an external regulator mounted on the guard.
My ign light is not working and battery is not charging.
I did find a broken wire at terminal "D" on the alternator and it has been repaired,but still no light with ign switch on.
Note light does come on when terminal D on regulator or alternator is shorted to ground.
Thanks Felix
1967 Morris mini Deluxe
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
1982 Jaguar XJ6 series 3
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Sat Nov 12, 2011 2:26 pm
Is the globe blown in the ignition warning light? That will prevent it from charging properly.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sat Nov 12, 2011 2:51 pm
Light works when terminal D shorted to ground
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Sat Nov 12, 2011 3:51 pm
The following thread includes a couple of page from my Lucas Australia Alternator book showing an exploded view of the internals and a wiring diagram. It's the 15AC you are after.
http://www.ausmini.com/forums/viewtopic ... alternator
PostPosted: Mon Nov 14, 2011 1:58 pm
I still cannot get the ign light to work wiith the key selected on,as I previously said light works when ind wire put to ground.
I disassembled the alt and the diodes and brushes are ok.
Could the external regulator be the problem
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
 Post subject: No Ign Light.
PostPosted: Thu Nov 17, 2011 6:07 am
If the Ignition light is not coming on when system is hooked up correctly. it means that either the Regulator or the Rotor coil are open circuit. It could also mean the brushes are worn and not connecting to the slip rings. Don't blow the regulator as they are impossible to get new and good second hand ones are few and far between.
"Let us remove your "SHORTS"
 Post subject: Re: No Ign Light.
PostPosted: Thu Nov 17, 2011 6:56 am
Can still get the 4TR regs new from UK.
Latest Lucas p/no is NCB148.
http://www.autoelectricsupplies.co.uk/product/706
PostPosted: Thu Nov 17, 2011 6:37 pm
auto electriciann checked the alt and it's ok.He said the reg is no good.
The original regulator was an 8TR.Is the 4TR the same.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Thu Nov 17, 2011 9:19 pm
i have an original 2nd hand reg for one of these if you`re interested
someone else asked me about one a while ago so i dug it out but they never got back to me about it & i`ve forgotten who it was anyways
PostPosted: Thu Nov 17, 2011 9:36 pm
1970 Cooper,
4TR superseded the 8TR. Main operational difference is you could adjust the voltage on the 8TR. NCB148 is the p/no now of the Mini 4TR one. Pinout is the same as the old 8TR.
Be careful which 4TR you get though, the Jag XJ6 ones look the same but pinout is different. As I found out....
[edit] my MiniMatic is also a 1970, it came with a 4TR fitted. So I'm not sure when the change occurred.
PostPosted: Fri Nov 18, 2011 6:17 am
Thanks Kevin,
I have ordered one from the UK
The 8tr I had fitted had no adjustment on it
Regards Felix
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Nov 18, 2011 7:05 am
1970cooper wrote:
Thanks Kevin,
Regards Felix
Adjustment screw (if it had one) was on the back...
PostPosted: Fri Nov 18, 2011 8:42 am
Hi Kevin,
I just got the old reg back from auto elect and noticed the terminal ident is different than the NC148
my original one is marked
B+/+/F/-
The NC148 is marked
?/+/-/F
I thought I would check with you before I order the reg
Thanks Felix
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
PostPosted: Fri Nov 18, 2011 11:42 am
I gave my NCB148 away with my 15AC alternator to a deserving cause (mate's Mk2S) and he is checking the pinout, however looking in the manual for 1970 Oz S and K etc, you are right, there it says + + F -.
I'll edit this shortly.
[edit] Yes the pinout on my NCB148 (bought here in Oz) is B+, +, F, - same as original.
Is the one you looked at an NCB148 or something different? (you typed NC148).
Could be for a Jag or Triumph or whatever. As I said their pinout is different (but can be used if you swap wires about)
PostPosted: Fri Nov 18, 2011 1:49 pm
sorry Kevin,
I miss typed it I did meanNCB148,if you look at the site in the UK you mentioned the terminals are as I said.
So if I just swap the wiring at the plug I should be able to yse that reg.
1968 Buick Riviera
1979 HZ Kingswood
1979 CM Valiant
2002 VX HSV
2013 Mazda 6
2018 Gt Mustang
Users browsing this forum: No registered users and 117 guests
