It is currently Wed Jul 23, 2025 1:49 am
PostPosted: Fri Apr 08, 2005 12:53 am
so your car is a roundnose 82 model Leyland??
PostPosted: Fri Apr 08, 2005 6:37 am
AFIA yep, I'll confirm when I get it back though :)
KiwiMR2
1996 Libero GT
1979 Mini Cooper 1.3i
PostPosted: Fri Apr 08, 2005 8:42 am
It would have been British Leyland, like my MK 3 (mutant)
mutant mini 1380cc '73 UK imp-Chroma Lusion-leather interior-8 x 300W Diamond Audio Dual Voice Coil 8" subs, Phoenix Gold 4 chnl amp, Pioneer 7550 DVD, 2x Phoenix Gold A1.800d MonoBlock Amp, Focal Utopia splits, 14" chrome rims 195/40/14 tyres
PostPosted: Wed Apr 20, 2005 5:29 pm
Right well it's here!! :D I picked it up late last night and drove it back home (no wof, rego, or bonnet!! :shock: )
Anyway I have since picked up the bonnet. 1st impression are.......sweet 8) The gear changes are nice and clean, no more crunching....and in general it's running smooth. Few things though......brakes, there are none :oops: well almost none, it does brake but even foot hard down it's hard to come to a stop. What do you guys reckon?? New pads or what?? My horn no longer goes but I’m guessing that's and easy fix (I need it for the wof though) I have no number plate light as prior to it going in for repair for like a year someone hit my mum from behind, there was a dent just under it so we pulled it off, a mate did a sorta patch up job so I guess I'll just re-attach it, how does it attach to the car??
The rear bumper is pushed in a bit :( which is JUST pushing against the bottom off the boot which is I assuming why the boot looks a tad open on the opposite side (closes but the thin line around is a lil bit more open on that side) I’m hoping when I pull the bumper away it will be fine. Are those bumpers repairable?? or should I TRY and find a replacement??
The descriptions on the invoice for work done are as follows:
Diff side seals
Strip engine off gearbox
Engine degreaser
Main shaft
Clutch plate
Clutch release bearing
Gasket/seal kit
Main shaft bearing
Syncro rings
Housing
Main shaft roller bearing
4th gear hub
Water pump
Front exhaust pipe and clap
15 hours labor all up :( $660 worth of parts.
Most of that stuff means nothing to me, LOOKS like a fair bit of work, worth the price I ended up paying I highly doubt though. One thing I noticed on the way home was the temp gauge in the car went up and down a fair bit, when I stopped for gas ($20 of 98 and a full tank...YAAAA, oh and a litre of oil as it was virtually empty) it was on almost the top hot BUT the engine seemed fine, we took the water cap off to top it up (was ALMOST full anyway) the water was brown, rust yeah?? If the engine was too hot we wouldn't have been able to take the cap off aye? It was WARM but not hot, and the water was WARM.
Now for some pics with questions etc:
What is the WIRE comming from the little white....thing, that seems to go down to the circle plastic bit and up to nothing?? shouldne't it be somewhere??
IF I can get this bolt off will it allow me to remove the steering wheel??
Assuming it does that means I can get this bit off and stop it from RATTLING!!!!!
Steering wheel is quite cool, says "Mini Royale"
Im obviously going to re-do the paint work, as you can see there are some bits that have peeled off.......1982 Leyland Mini, round nose yeah??
Engine shot:
Sorry....hard to read, mean anything to anyone?? I can see something .AU there, means Aussie??
That's the temp gauge that was going up and down:
Where to put front speakers??
Standard wheels yeah? I mean would it have come with these??
These:
Could be replaced with these??
These could go in place of the front orange ones yeah??
That's it for now :)
KiwiMR2
1996 Libero GT
PostPosted: Wed Apr 20, 2005 5:32 pm
you've definitely got one rare car there
i dont know much about them at all
never thought Leyland made round noses
did it come from enlgand
is this one of the early MK3s
Inconspicuously Conspicuous
PostPosted: Wed Apr 20, 2005 5:39 pm
Well actually Im only saying it's a Leyland as that is what it is registered as....that doesn't mean it is one though, it's what ever the person that brought it into the country called it, even if they didn't exactly know what it was, assuming the description was SIMILAR to what it looks to be they would allow it to be called that. Is there any way I can REALLY confirm what it is??
KiwiMR2
1996 Libero GT
PostPosted: Wed Apr 20, 2005 6:33 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
it would be a british leyland ... au is something to do with the company that sold it by the look of the id plate yup remove the nut and with some persuation the boss will come of .. but what is rattleing the black bit behing the steering wheel prolly just needs tightning
makka
PostPosted: Wed Apr 20, 2005 6:40 pm
makka
If you look in the 3rd pic down, that black peice sitting roughly 2cm from the nuts on the bottom of the steering wheel is not attached to anything. It can move freely up and down and just sits there rattling, I guess it should just be stuck to the bottom of the steering wheel?
KiwiMR2
1996 Libero GT
PostPosted: Wed Apr 20, 2005 6:42 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ahhhh ok i see said the blind man to his deaf dog
yeah just undo the nut you may have to jolt the wheel of though
makka
PostPosted: Wed Apr 20, 2005 7:22 pm
Australia was the only country that had "Leyland Minis"
The UK built Minis were never badged as Leyland Mini.
They were Austin and Morris and then they were just Mini, then towards the end they were called Rover Minis.
Your car is a "Mini" made by Leyland.
My 1275LS is a "Leyland 1275LS" made by Leyland.
My 1968 Cooper S is a "Morris Cooper S" made by BMC.
PostPosted: Thu Apr 21, 2005 1:02 pm
The car you have would be a British Leyland. I have a Mk III (mutant). You have a Uk import or could be South African.
Not sure if yours would have been MK III or later model. Mine is a 1973 which is a Mk III.
The plate under the bonnet you have is the exact same as mine.
My interior looked like that also and so did the bonnet badge.
PostPosted: Thu Apr 21, 2005 3:31 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
hey mutant i thought un zed got mini's till the late 80's
hmmmm maybe i should get my mate tum (tim) from unzed to get on here and help out our kiwi mate
makka
