It is currently Sat Aug 16, 2025 9:27 am
PostPosted: Tue Nov 15, 2011 2:36 pm
Hi guys, going to attempt something silly,,, Going to try and get the engine out with out removing the brake booster..
Has anyone done it?
PostPosted: Tue Nov 15, 2011 2:50 pm
I would suggest it is not possible through the top but only by dropping the engine and subframe?
Whats the reason? Hate bleeding the brakes? My wife will agree :wink:
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Nov 15, 2011 2:52 pm
Depends, if you have the two lines to go to the booster as braided hose, you could remove it without disconnecting it, otherwise I'd say its a bit tricky.
PostPosted: Tue Nov 15, 2011 3:00 pm
the pipes are quite "pliable" & will "usually" cope with a slight bending, so you can often take the mounting braket bolts out & lft the booster away leaving the pipes all bolted up, then just rest the booster ontop of a decent comfy rag on the guard or wiper panel
we`ve done it this way heaps over the years, but only occasionally we get the odd rusty brake-pipe & they can crack,,, then you just have to change it over anyways, & beter to find it crack now than later anyways
it`s easy enough, just be gentle
PostPosted: Tue Nov 15, 2011 3:15 pm
If you incorporate two rubber hoses (like the ones from the rear radius arms) into the pipes, it can be done. I don't see why they need to braided? :?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Tue Nov 15, 2011 3:17 pm
I just beant mine up over the wing, worked perfectly and went back into place without an issue, you do need to be delicate with the bending though
PostPosted: Tue Nov 15, 2011 3:22 pm
Yeah brand new pipes and they are alll the way over to the left, so it should work.... Thanks guys!
PostPosted: Tue Nov 15, 2011 3:29 pm
I'd only be going braided to try and reduce flex in the lines for better pedal feel, they shouldn't be copping stones up there so damage won't be a problem.
PostPosted: Tue Nov 15, 2011 3:30 pm
Yes, that makes sense Harley.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
Users browsing this forum: No registered users and 277 guests
