It is currently Fri Aug 22, 2025 8:28 am
 Post subject: Spark plugs??
PostPosted: Thu Nov 17, 2011 7:22 am
Hello All, What spark plug do you reccomend, 1098 motor??
cheers TSB
PostPosted: Thu Nov 17, 2011 7:27 am
I used nothing but NGK BP5ES in my 1098.
PostPosted: Thu Nov 17, 2011 8:14 am
i use BP6ES its the standard plug that rover used in the A+ motors ..
998 and 1275
Beanie
I am the son of the STIG
HOTBRICKS
http://hotbricks.org.au/
'65 NCF MINI.....
PostPosted: Thu Nov 17, 2011 10:47 am
BP (or was it Bosch, I can't remember) on their website recommend going 1 heat range hotter than original, for general commuting running unleaded fuel.
So, BP6ES>BP5ES.
Unless you are thrashing it I'd say the 5s better suit a 1098 anyway.
I'm using 5s in my 114HP 1412 roady, no problemo. 8)
[edit] these are BPR5EY, are a little longer projection than ES but the same heat range.
Last edited by drmini in aust on Thu Nov 17, 2011 12:53 pm, edited 1 time in total.
PostPosted: Thu Nov 17, 2011 12:29 pm
I'm with the Doc,
I use BP5RES in my 190hp turbo 1293 motor.
they worked best on GR's dyno so thats all i use on the road.
big boost and track days i also have used B8EGV but they are a little too cold i think.
Grant
100% Pure A Series Turbo
PostPosted: Thu Nov 17, 2011 12:51 pm
ausmini mod
ausmini mod
I used to use BPR5ES also however since winding up boost etc ive gone to BPR6ES
I would stick to the 5's for a normal and mild 1098 and 998
Pete
PostPosted: Thu Nov 17, 2011 12:58 pm
NGK, BPR6EIX.
PostPosted: Thu Nov 17, 2011 1:20 pm
ausmini mod
ausmini mod
TK wrote:
NGK, BPR6EIX.
Why would you use Iridiums in a classic Mini?? Just a waste of money imho (in fact, I even ran normal plugs in my XR8) just change them more often.
Each to their own but I dont think there is any advantage (even the fact they dont need to be changed as often)
Peter
PostPosted: Thu Nov 17, 2011 1:23 pm
I found much easier starting.
PostPosted: Thu Nov 17, 2011 1:30 pm
ausmini mod
ausmini mod
Really? Wow... you tried both the iridium in a 6 and the normal 6ES ? And the iridium helps with starting? Thats pretty cool.
Are you still running a dizzy or gone electronic?
Pete
PostPosted: Thu Nov 17, 2011 6:20 pm
I'm using electronic ignition.
PostPosted: Sat Jan 07, 2012 11:56 am
Champion- N9YC
Bosch- W8DC or W6DC
NGK- BP6ES
