It is currently Sat Aug 02, 2025 10:00 pm
PostPosted: Fri Nov 18, 2011 1:40 pm
Mods rock!
When checking the pinch bolt, make sure the slot still has a gap.
If not pull it out and run a cutting disc into it.
Sorry don't want to sound like a knocker, but this is a serious safety issue.
If there is NO gap, the splines have gone. Put another coulmn in it.
<EDIT> Somewhere I have a BMC Service Bulletin that coves this and why it appears that the column still has spines and why they should NOT be 're-gapped' and reused. The width of the original gap is a wear limit indicator. I'll dig it out and post it up.
PostPosted: Fri Nov 18, 2011 2:07 pm
ausmini mod
ausmini mod
GT - I see your point... but I understood what Kev meant too... he just didnt write the little details.
If the spline is FINE, and no gap (for ANY reason) - its possible... then cut a groove, if the spline is stuffed - well, new column it is.
Ill be pulling it apart tomorrow and will update with pics too!
Pete
PostPosted: Fri Nov 18, 2011 2:18 pm
pristic wrote:
So Doc - in your medical opinion - its the spline on the column?
If it is, I have been thinking about a mod anyway - and replacing the column completely ...
Will see how we go tomorrow.
Pete
IMO it's the spline gone- it would spin right around except you probably have a Clubby rack with the slot (not a groove) cut in the pinion, so it just moves to and for.
Like GT m says, if the spline in the column is rooted, bin it..
PostPosted: Fri Nov 18, 2011 3:25 pm
ausmini mod
ausmini mod
Kev, which steering columns fit? Do Rover ones fit? I wouldnt mind changing the whole lot including the shroud, blinker assembly, etc.
Pete
PostPosted: Fri Nov 18, 2011 5:42 pm
Not always.
Check the splines if they are still ok and there is no gap then run the cutting disc down the slot.
If the splines are stuffed fit a new column.
PostPosted: Fri Nov 18, 2011 6:06 pm
Pete
You could fit a Rover one but I don't know what the length and detail differences are.
Bottom spline is the same really.
I may have a spare Clubby shaft here, will check tomorrow.
PostPosted: Fri Nov 18, 2011 6:57 pm
Any mini column will fit, all are easy except for when the column wiring doesn't match the car loom.
PostPosted: Sun Nov 20, 2011 6:29 pm
ausmini mod
ausmini mod
Ok, spline on the steering column - what spline? Unbelievable! Absolutely no spline left! It was fine fine fine until a few days ago and then NOTHING - well, I was lucky is the truth!
So, replaced the column and its sweet as. While I was there, I undid the rack and re-aligned it with the column...
Pete
PostPosted: Sun Nov 20, 2011 6:43 pm
Pity we cannot buy new Oz steering column shafts. :cry:
Mini King has new old stock unmachined Leyland forgings for the lower clamp lugs, however I cannot find anybody who has a pull-type broach to machine the splines:
9/16” SAE std spline, 36 serrations, 45deg straight.
I did get a price to CNC machine these from bar stock and then wire cut the splines, but it was too expensive to do a limited quantity.
PostPosted: Sun Nov 20, 2011 8:43 pm
Funny exactly what happened to me. PO lowered column ... splines went so replaced column & put back to original settings. sweet as.
Good to hear all is sorted.
PostPosted: Sun Nov 20, 2011 9:14 pm
I don't know what a pull-type broach is for machining the splines, but the shaft is fairly soft compared to the pinion yes? Could you not use a vice to hold the clamp tight whilst you drive a pinion into it, which would re-spline it?
PostPosted: Sun Nov 20, 2011 9:25 pm
It's 'soft', but not that soft.
You'd end up with a pretty shitty self-made spline :lol:
They definitely need to be a machined spline, for fitment and longevity!
PostPosted: Sun Nov 20, 2011 10:15 pm
Maybe i should ask if you have actually done it and if so what were your thoughts
PostPosted: Sun Nov 20, 2011 10:18 pm
No I have never done it because it's a pretty nonsense thing to do; especially for a part that is so important in terms of safety.
Who is to say when you are driving the pinion in it, there is not a slight rotation and you're damaging the spline you 'cut'.
The highs on this spline would also be quite weak as you've essentially just smashed the metal around it - there is no integral strength as there would be with a machined cut.
PostPosted: Mon Nov 21, 2011 8:01 am
To cut a new spline, you need a new forging for the bottom of the column. These were splined almost right through, as the shaft has a spline too. The forging was then welded to the shaft on assembly by BMC to stop it coming off.
The spline is a precision fit, it has to be machined, or wire cut by a toolroom.
So, it's not a real easy fix. The main problem is that although new forgings exist, they are unmachined.
