It is currently Sun Aug 03, 2025 12:57 am
 Post subject: speed bleeders
PostPosted: Sat Nov 19, 2011 7:49 pm
Resident Haemorrhoid
saw these
http://www.murphskits.com/catalog/produ ... cts_id=138
and thought they could be useful
I know they are on a motorbike website but they could be fitted to a mini if you could get the right size
BTW what size are Mini bleed nipples and are they the same size for each application Brakes / Clutch ???
mtsmini wrote:
Tombo wrote:
PostPosted: Sat Nov 19, 2011 9:09 pm
Sounds great! Would hate to have one fail though....
Mine are different from rear drums to front discs to booster.....Another way to make bleeding annoying lol
'63 850/1100 + more cooper goodies
PostPosted: Sun Nov 20, 2011 9:59 am
They used to be available from Mini specialists in the UK back in the '70s. I've got them on my Cooper S and they are still working fine.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Nov 20, 2011 10:23 am
Theyre still available from earls/speedflow/aeroquip and those sort of people.
Simplify and add lightness
PostPosted: Sun Nov 20, 2011 1:30 pm
it's not any different to a normal bleeder, so would be no more likely to fail. Think of it as a normal bleeder with a check valve inside. When the bleeder is tightened, it's mechanically sealed and the check valve doesn't do anything
booster should be the same as discs, and drums are different front to rear so fitting those isn't a lot different to the standard setup
discs and clutch are 3/8UNF, can't remember what the rears and front drums are
PostPosted: Sun Nov 20, 2011 1:34 pm
You could always go about it this way instead. http://www.ezebleeder.net/
PostPosted: Sun Nov 20, 2011 4:24 pm
ive done the same as the ez bleeder, but with a Tom Thumb pump from autobarn only cost a few bob, and you can use the pump for any vehicle fluid, only problem is you can push dirt from the bleed screw into the brakelines, better to go from the top
1969 Blue Mini K, 1330cc, Weber 45, polished aluminum roll cage, Race seats, 4 point harness, full rewire incorporating 8 fuses, 6 relays and new headlights :) just needs tyres front shocks and a windscreen til re-register
PostPosted: Sun Nov 20, 2011 7:40 pm
pretty cool idea
of all cars i have owned minis are the worst to bleed brakes on
--Insert legal disclaimer here--
