It is currently Fri Jul 18, 2025 10:56 pm
PostPosted: Thu Nov 24, 2011 4:57 pm
So ive got my subframe out.
Ive wound the spring compressor into the thread of the donut enough to grab solidly.
I start to wind the other handle to provide pressure against the top of the subframe tower.
When I wind this it becomes incredibly hard.
When I wind the top handle the cone rises.
I wind until the bottom of the cone rises out of the knuckle.
Am i supposed to be able to pull the cone out now?
It wont budge, solid.
Tried levering.
Twice Ive resorted to just pulling the compressor out again.
PostPosted: Thu Nov 24, 2011 5:09 pm
So you are trying to remove the strut (cone) from the donut yes?
It is most likely corroded itself to the point it is now thoroughly stuck in the donut and will require some serious persuasion to remove it.
If you have the subframe out of a car it would probably be easiest to remove the upper control arm, then the strut will drop lower and you can chisel it apart from the donut easier (air chisels work great). Then you can also remove the donut easily as it's probably cactus as well.
I dislike the idea of trying to separate the strut from the donut whilst it is being compressed, as the threads in the donut probably aren't very good which may be an accident waiting to happen
PostPosted: Thu Nov 24, 2011 8:22 pm
Remove the Top Arms
Remove the Cone Compressor tool
Put a 1/4" steel rod through the rubber donut centre hole & hit with BFH
The cone will be rotten & unusable anyway so bang away
Had to do this when we put HiLo's in...hint...put copper grease between cone & donut when refitting.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Fri Nov 25, 2011 1:02 am
Tomboss Breweros
I agree, top arm out.
Those old cast alloy cones get stuck really good, i've had to smash one entierly out for Jimmyinamini.
As Jeff said, copper grease on assembly is well worth it, and make sure whatever you put back, cone or hi-lo, has a drain hole for any water that gets inside it.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Nov 25, 2011 6:18 am
Cheers guys.
I'm not going to hesitate to force them out.
Brand new donuts and hilos going in.
