It is currently Tue Aug 05, 2025 1:59 pm
PostPosted: Tue Nov 29, 2011 2:19 pm
Hi Guys
Hoping some of you gurus out there can point me in the right direction.
I have a 1967 S, motor is not quite standard. I have never had the head off, but appears to have flat top pistons and a little bit of porting work. I also suspect a non standard cam, doesn't idle nicely under about 1200 rpm.
I have just reco'd some 1.5" SU's which currently have 0.090" (swing) ADX needles. I have these wound up as far as they will go, but it is still running lean up to about 3000 rpm.
Any ideas which needles I might need?
Thanks
1964 Morris "Cooper S" Group Nb Racer
1965 Morris 850
ex 1967 Morris Cooper S
ex 1969 Morris Van (Rover SPI running gear)
PostPosted: Tue Nov 29, 2011 3:15 pm
If you can fit fixed needles try some No 4,s , its the same needles as the Police Cooper S
PostPosted: Tue Nov 29, 2011 3:52 pm
cops used CP4's
#6's were good in my car with twin 1.5's - I think ex. Dr Mini's Barney uses #6's too
see here for a comparison of #6, your ADX and a couple of swingers that are roughly equivalent to #6
http://www.morrismini.com/SUNeedlesV2.a ... &size=.090
edit: it's easy to convert a swinger to fixed, and I reckon you could go back the other way with some araldite to glue the collar on
PostPosted: Tue Nov 29, 2011 3:55 pm
My motor is similar but I think my cam is standard Cooper S.
I tried a few and settled on No.6. fixed needle. Seems to run well but never have had it analyzed properly.
PostPosted: Tue Nov 29, 2011 3:57 pm
looking again, that ABD needle would be worth a try I reckon, I had CP4's, and they were too rich, even the #6's were rich at idle & cruise. ABD's would give you a bit of meat to sand off
PostPosted: Tue Nov 29, 2011 4:12 pm
Awesome, thanks for your help guys. Will have a read see how I go.
1965 Morris 850
PostPosted: Tue Nov 29, 2011 4:33 pm
Yeah , I got myself front to back , meant to say CP4,s
PostPosted: Thu Dec 01, 2011 10:52 am
So what do I need to do to convert the swinging needles to fixed?
1965 Morris 850
PostPosted: Thu Dec 01, 2011 11:03 am
to take a swinging needle and put it in a fixed dashpot piston, all you need to do is tap the collar thingy off it and linish the knurling so that it fits in the base of the piston
but if the carb has a swinging dashpot piston, I think you need to replace it with a fixed piston...
PostPosted: Thu Dec 01, 2011 11:17 am
Yeah, I think I have the swinging piston. Will go through the carby box in the shed to see if I have the fixed ones. Makes sense that I need to replace the piston.
1965 Morris 850
PostPosted: Thu Dec 01, 2011 11:23 am
Simon, I think there is/was an adaptor you can get to fit a fixed needle in a swinging piston..
ps. don't forget to fit a new jet with your fixed needle- those swingers wear the jet out. :x
PostPosted: Thu Dec 01, 2011 12:01 pm
yeah, I figure one would/did exist...
PostPosted: Thu Dec 01, 2011 7:51 pm
im not sure what needles my 1 1/2 have so i took one out, looks like FX on the needle? anyone shed some light
PostPosted: Thu Dec 01, 2011 7:52 pm
PostPosted: Thu Dec 01, 2011 9:06 pm
FX is leaner than a no 6, which in turn is leaner than a CP4.
