I've been reading this and mulling over the reply.
MIG welders should really come in the standard mini service kit, a bit like the jack or lug nut wrench.
The front apron would make an ideal project for someone who's bought a reasonably good MIG, done some practice and worked out the right settings for the panels they're working on.
The roof is a different matter. If
all the roof seam is like that, I'd farm the welding out and do the rest of the prep and paint. The best bet would be to find a cheap-ish but reliable old school panel beater. It's not a terrifically hard job, but if you stuff it up it's very hard to put right, especially being a roof.
If it's localized, perhaps once you've done the apron your skills and confidence will be up to tackling the roof. You'd need some way of bending the sheet to form the seam/flange and probably do it in as big a length as you can manage in the folder. You should also joggle the edge to try and prevent warping. It will need a bit of attention and patience but do-able.
It's a hard one to call. I've bitten off more than I can chew before and regretted it. Projects like this are quite a bit longer than you think at the start. You'll need a bit of kit, such as angle grinders, welding gear and
personal protection (gloves, a decent auto welding helmet) and so on.
I don't want to put you off. I've also seen some guys produce some stunning results, but I've made enough mistakes to make me realise that a bit of kindly advice (ha ha!) at the beginning makes all the difference.
Now, having said that, get yourself over to
this thread on the MIG Welding Forum for some inspiration. This project makes me happy. The guy's just turned 21 and his car is going to be unreal. Incidentally, all you need to know is on that forum. It's the best site on the net for learning and mastering MIG welding. If you have the time, space and dedication, there's no reason you can't do it. Just be realistic about the time you can put into it.
