It is currently Sat Aug 02, 2025 1:48 pm
 Post subject: Easy Q heater core
PostPosted: Sat Dec 10, 2011 12:59 pm
How is the heater core plumbed in. Outlet above cyl # 4 to inlet heater core . Where does outlet hose go to?
C told u was easy.
PostPosted: Sat Dec 10, 2011 1:08 pm
Bottom hose always, if it's in the heater.
If it's an aux radiator being fitted, some people plumb it into the top hose with a T fitting.
Mine uses the Matic heater, it's plumbed into the bottom hose as stock and works just fine. :wink:
PostPosted: Sat Dec 10, 2011 2:35 pm
I just read what I wrote and im retarded.
Start again... doc it is going to be an aux radiator.
Which hose is inlet on core? Top or bottom?
Where does outlet hose from core go to?
Thanks :D
PostPosted: Sat Dec 10, 2011 2:40 pm
Top of core to back of head, bottom of core to bottom hose, is convention.
But really, it will still work either way. :wink:
PostPosted: Sat Dec 10, 2011 3:55 pm
Ah k no worries thanks doc
Users browsing this forum: Bing [Bot] and 105 guests
