It is currently Thu Jul 31, 2025 8:59 am
 Post subject: weber..dcd..2836
PostPosted: Sat Dec 10, 2011 2:39 pm
hi all mini men ....have a 1330 gt motor with worked head inlet 37...exh..35...10:1 compression....648 cam ... has a 28..36 weber that needs jeting....any help would be great. cheers minimick...ps weber was on stardard cooper 998.
PostPosted: Sat Dec 10, 2011 3:25 pm
Really I think the best way is to take the car to someone who has a dyno and a supply of jets. All engines are different and you need to match the jets to the engine over a range of revs and loads.
Somebody here could suggest a number of jets that might work but without the analyis you dont know if its running lean at critical revs. That could be disasterous as you could burn holes in pistons.
Does it start and run atm with whats in the carby ???
Mike
PostPosted: Sat Dec 10, 2011 9:30 pm
hi. thanks for the reply....it does start with alot of choke ..but seems to be gettin to much fuel ..runs for a bit then stops.....will sort it out...i like a challenge.
Users browsing this forum: drmini in aust and 94 guests
