It is currently Tue Jul 22, 2025 8:23 pm
PostPosted: Mon Dec 12, 2011 7:16 pm
Anyone ever had experiance with using one of these?
If so what is your opinion?
Mini's I grew up with
Slot car couch
PostPosted: Mon Dec 12, 2011 7:22 pm
Had one in my rover, they're great if you prefer to sit further back and lower than normal.
I don't have one in the current car, I like being able to get in and out easier. :lol:
PostPosted: Mon Dec 12, 2011 7:40 pm
I like them.
When fitting keep the Steering Colmun Attached to the spline on the rack but loosen off the steering rack U Bolts when your happy with the position lock in the Column and then the U bolts. If you Don't you with Stuff you Steering Rack
PostPosted: Mon Dec 12, 2011 8:19 pm
I used to have one of those but it kind of looked a bit flimsy considering that this is what the column pivots around in a frontal collision. If it snaps instead, then the column and wheel is likely to head straight for your face.
Now my face might not be the best looking one around, but its the only one I have, so I upgraded to this one made by one of the blokes on the UK Mk1 forum.
michael
PostPosted: Mon Dec 12, 2011 8:38 pm
Hey that looks pretty nice, mick. Got more details on how to get one?
PostPosted: Mon Dec 12, 2011 8:59 pm
tomkidd on mk1 performance forums was the guy who had them made.
It looks like he sold his last one in June.
If enough people pester him, he will have another batch made I think.
They came powdercoated black or nickel plated, in standard length and longer than standard.
25 quid posted to NL if i recall (it was 2009!)
michael
PostPosted: Mon Dec 12, 2011 10:09 pm
A bloke on www.theminiforum.co.uk has recently started selling a similar design, in two sizes. First is apparently the same drop as the silver one in your original post, the second drops it a further 30mm. I can't comment on the respective qualities but they are similar in appearance to the Kiddspeed item that mickmini posted, although note the circular vs trapezium cutout on top and the slot cutout for fixing the steering column angle vs the 3 pairs of holes for same.
That said, I'm thinking of ordering one. Also makes a harness bar, seat rails, etc if you're into that kind of thing. See JB Fabrication on Facebook for more pics and information.
the internet wrote:
Like Audrey Hepburn, almost everybody loves the Mini. The only people who didn't love the Mini were pathetic, empty people.
PostPosted: Tue Dec 13, 2011 8:15 am
gafmo wrote:
I like them.
VERY IMPORTANT! Listen to Gafmo you do!
Lillee - 1969 Morris Mini K
PostPosted: Tue Dec 13, 2011 8:51 am
Thanks for the info everyone 8)
Looks like there are a few options available.
It would be cool if a pressed steel one was available that looked very similar to the original. Hmmm, wonder if there is a way? If I was still toolmaking would have the resources to create something...
None the less some of the other examples you guys have posted look pretty good, I will check them out.
Slot car couch
PostPosted: Wed Dec 14, 2011 10:40 pm
:idea: I have the part you linked in the original post installed for the past 5 years or so, no problems at all
PostPosted: Wed Dec 14, 2011 11:16 pm
I find if you have the original large steering wheel fitted then the original angle (ie without the above bracket) works well. Once you start to have a small sports steering wheel then the wheel starts to feel too far away.
Advantages...
* Looks period (they were a period accessory)
* There is a range of positions
* Relatively easy to fit and/or remove
Disadvantages
*Looks a little ugly.
*Could be argued that the column is slightly more dangerous in an accident. The Mini's more upright steering column angle helped it to bend forward and away from you in an accident rather than spear you through the chest.
Just ask Sir Sterling Moss :wink:
Users browsing this forum: Aussie Brian and 83 guests
