It is currently Tue Aug 19, 2025 12:07 am
 Post subject: Nylon Hydrolastic lines
PostPosted: Tue Dec 13, 2011 8:26 pm
Hi all,
Anybody ever had anything to do with these. I need pipes made but this seems a cheap option, wonder how it would handle pressure. I think hydrolastic system is only supposed to get pumped to 260psi ish? Spose there spike pressures in the system when travelling that would go a lot higher?
http://www.minispares.com/Product.aspx? ... 478&title=
Mini's I grew up with
Slot car couch
PostPosted: Tue Dec 13, 2011 8:29 pm
Also these ones,
http://www.minispares.com/Product.aspx? ... 710&title=
Really I could go get some of this copper roll and make some of these myself as Doc suggested used fittings of old ones that are no good.
Slot car couch
PostPosted: Tue Dec 13, 2011 8:36 pm
I am curious too on how these will go
anyone tried these versions? I'd like to overhaul my 43 year old tubes and the original versions don't look like they'd make it from the UK safely
PostPosted: Tue Dec 13, 2011 8:40 pm
I think the nylon lines would be OK, in one of my previous lives in the late 60s I worked on Formula Vees. Many of these ran 1/8" `nylon 11' tubing as hydraulic brake line, all the way from the MC to the wheel cylinders. This line was rated to 2500psi, but of course it was small diameter.
The Minispares pipe you show would be much lower rated.
When I do the Clubby van next year to hydro it will either get steel pipes as original hydro cars (but longer), or else I'll run hydraulic hose the full length.
If you want steel pipes, I believe Mini King can get them made.
PostPosted: Tue Dec 13, 2011 8:46 pm
The nylon pipes would handle the pressure, I know some 1100 people have used it in the past without any problems. If you want the specs look up Parker Parflex nylon. It should be available locally from Enzed
What is wrong with getting steel bundy tubing though? It should be easy enough to get. The pipe should be available locally. It is used on hydraulics on machinery.
PostPosted: Tue Dec 13, 2011 8:48 pm
really? I asked about this a while back and didn't get a too positive response
I do hope I am wrong tho as I'd be keen on chasing this up
Just keep the original UNF flare fittings as Pirtek may not have them (no I've not checked but I've heard this in the past).
PostPosted: Tue Dec 13, 2011 9:16 pm
They are available
http://shop.fluidair-power.co.uk/sub_ca ... Id=79&lm=2
PostPosted: Wed Dec 14, 2011 11:07 am
The Mini King
I am sorry if I or someone else came across as less than positive, I do have these made.
however I do not always have them in stock, it is also important that I know the year model
as there are two very different models
Regards
John
PostPosted: Wed Dec 14, 2011 5:36 pm
For DrMini
Kevin
Some time back I was talking with you (on here) about converting a van into hydro and you mentioned the rear subby needed some conversion work to fit. You said we could come to agreement on this conversion.
I plan to start on this late jan or feb - is the offer still open ???
Mike
PostPosted: Wed Dec 14, 2011 6:09 pm
Hi John, no offence intended - I think it was the first time I visited your place and on an open day, I had a shopping list for my newly on the road Miniand the place was very busy. I asked about the hyrdo lines and the answer was vague from memory so assumed the answer was no
if you can get em, I'll be looking into this in the new year for sure for my 68 Mini Matic
cheers again
PostPosted: Wed Dec 14, 2011 8:46 pm
Mike_Byron wrote:
For DrMini
Kevin
Mike
PM sent. :wink:
PostPosted: Wed Dec 14, 2011 8:52 pm
Mike_Byron wrote:
For DrMini
Kevin
Mike
PM sent. :wink:
I'm also interested in details of the mods required on the rear subframe for a hydro van. I'll contact you directly Kev.
Steve
PostPosted: Wed Dec 14, 2011 8:54 pm
I will take a pic of the frame that Les (Alpine Moke) modified, on the weekend.
PostPosted: Wed Dec 14, 2011 9:06 pm
J844 nylon airbrake hose.
This is used to supply the air for both the braking systems on semi trailers and also their airbag suspension systems.
I reckon that if they can bounce around 20 ton monsters, then a mini will be fine.
Only question I dont know is, how does the nylon go with hydro fluid?
mooo, I'm a pig!
Users browsing this forum: No registered users and 119 guests
