It is currently Tue Aug 19, 2025 2:47 am
PostPosted: Wed Dec 14, 2011 9:41 pm
micowen wrote:
J844 nylon airbrake hose.
This is used to supply the air for both the braking systems on semi trailers and also their airbag suspension systems.
I reckon that if they can bounce around 20 ton monsters, then a mini will be fine.
Only question I dont know is, how does the nylon go with hydro fluid?
Nylon 11 was/is fine with regular brake fluid (which is glycol) on Formula Vee race cars as I said.
Some people here run the original hydro fluid (water + alcohol)- others run glycol +water 50/50.
Nylon is pretty tuff stuff, I doubt Minispares would be selling it for hydro use if there was a problem..
PostPosted: Wed Dec 14, 2011 9:44 pm
I have ordered some of the minisport flexible hoses as my delux has a small weep in one of the bends when they show up I will fit them and let you know how I go, may not be for a while as I don't knoe how long thay will take to get here
Don't under estimate the power of a Mini
1975 Supercharged Blue Mokezilla ;)
1976 Fudge Moke
1967 BRG & White 67 Morris Deluxe
1974 Clubman Mini S
2005 Red Mini Cooper S
2009 Mitsubishi Outlander VRX
PostPosted: Thu Dec 15, 2011 3:48 pm
Nylon air brake hose is not good enough by a long shot. Air brakes and air springs only run around 80 > 110 psi of air.
The proper nylon hose to suit hydro is going to be a lot different than air hose.
PostPosted: Sat Dec 17, 2011 3:26 pm
I will take a pic of the hydro frame that Les (Alpine Moke) modified for a van, on the weekend.
Here's a few pics-
The next couple we are doing will use 50mm x 50 x 3mm `C' channel as we have stock.
Users browsing this forum: No registered users and 286 guests
