It is currently Mon Aug 04, 2025 5:23 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Sun Dec 18, 2011 8:01 pm
Resident Haemorrhoid
Doc i thought of back flushing the oil line with petrol after dumping out the oil in the hope it will dissolve the Vasoline or would diesel be better?
Or would i be doing irretrievable damage to the oil pump????
mtsmini wrote:
Tombo wrote:
PostPosted: Sun Dec 18, 2011 8:03 pm
I'd use diesel... unlike petrol it has some lubricating properties.
But if still NFG, either the strainer is blocked or it's sucking air.
PostPosted: Sun Dec 18, 2011 8:23 pm
or, the oil pump pegs could be broken
or maybe there`s no oil pressure relief valve fitted, or not seated
or the oil pump bolts are too long & not nipping the pump to the blo9ck properly
or,,, any number of other reasons
but--> I reckon vaso is crap for priming oil pumps (just my thoughts from hearing & seeing sooooo many people get stuck with it over the last 40 (Plus) years)
& i use STP to prime pumps & never a problem even when left for years & years before starting, "ALWAYS" gets pressure up within 20-30 secs
PostPosted: Sun Dec 18, 2011 8:35 pm
STP costs $$, so I use a little 140 gear oil. :wink:
PostPosted: Tue Dec 20, 2011 10:02 pm
don't put thick sh*t in there, really good way to bust a pump drive. If it doesn't pump engine oil, putting thick stuff in won't fix it. Undo oil preesure switch and pressurise into it with compressor, hold pressure for 10mins, that'll push any vaso out, then prime with oil can, if you still have nothing you'll need to pull the engine
PostPosted: Wed Dec 21, 2011 6:44 am
ah,,, we`ve been using STP for more than 40 years, me , my dad, all our mechs (probly more than 40 mechs that have come through our workshops over the years) Robbo & his mechs & there`s plenty plenty more who also swear by it also
not one broken pump drive from using STP,,, period
i`d imagin that`s well into the "Thousands" of engines we`ve collectively built using STP
PostPosted: Wed Dec 21, 2011 9:56 am
it's pushing bubbles out of the line from the oil pump, and the sump is full - air is being sucked in - strip it
I took your advice on that Matt with my last 2 engine builds (mine and one for a mate) and it worked a treat. The last one I also mixed moly grease in with the STP and used it as assembly lube. Made the most beautiful black sticky goo :D
peterb wrote:
I take out the oil pressure switch and using a bit of 3/16" rubber vacume hose and oil can, pump as much as you can in. Works every time for me.
I do that also, but with a 1l pressurised oil tank- fill the tank up with oil, then pressurise it with the compressor and blow it through - oil comes up through the rocker shaft
