Mike_Byron wrote:
Yep - always a fine line balancing what you would a car to be and what is practical on the road.
The reality is that mostly you have a car potentially very quick but you rarely get to use that performance and its just plain hard work driving it around.
Mike
As Mike said, the reality is that unless your building a track or rally car and you need it reliable up to 180kph , its much more fun and practical building a car with a wide useable torque band and thats comfortable sitting on 100kph, with the rising cost of 1275,s there is a quiet revolution of people going back to basics and really enjoying a well built small bore , the sort of people I see getting out and about using their cars , the sort of people who I know will have a Mini on the road for Christmas
Now going back to Cams VS high lift rockers / roller rockers , the ones I know work very well are the Corolla rockers that Mr Green makes as he has calculated the load spread, and they would be probably first on list if I wanted higher lift , now over to Cams , most of the original cam grinders all based their cam grinds on the standard ratio 1.25 , Waggot , Speco Thomas to name a few
From the air intake through the SU where your making the first stoichiometric ratio ,a swinging or fixed needle, to the CFM through the manifold , to the inlet air velocity and the size of the inlet valves , the size of the chambers and your compression ratio , the exhaust ports and port matching to the gasket , all of that has to be taken into consideration before you choose a cam and a change in rocker lift
