It is currently Tue Aug 19, 2025 8:48 am
 Post subject: help ...
PostPosted: Wed Jan 11, 2012 6:54 pm
ok guys heres is my prob on closer inspection of my 1962 morris mini bodywork i have found some bad metal rot in the area to which the rear subframe fixes too drivers side,
the subframe was only held by the bottom bolt the top bolt was just in the subframe holding onto fresh air this part of the car needs to be repaired but i am not sure what these parts are called which need replaced .
i know that the parcel box needs replacing but not sure what the part is called that the subframe attaches too i have looked up body parts but not sure which part i need ...
PostPosted: Wed Jan 11, 2012 7:55 pm
a pic would help a lot. It's either the sill area or the area just above the seam. Try posting some pics of the rusty areas and we'll see how we can help.
PostPosted: Wed Jan 11, 2012 11:16 pm
have a look at this PDF, it'll help identify what you need...
http://www.somerfordmini.co.uk/pdfs/Cat ... riolet.pdf
the rest of them are here: http://www.somerfordmini.co.uk/pdfs/body-panels.html
Users browsing this forum: No registered users and 297 guests
