It is currently Mon Aug 18, 2025 8:50 pm
 Post subject: mini tool box
PostPosted: Wed Jan 11, 2012 5:00 pm
Going to put together a tub to put in the boot of stuff that I hope I will not have to use , but just in case
What do mini owners carry with them ?
Just in case
Mark
PostPosted: Wed Jan 11, 2012 5:08 pm
Mobile phone.
:D
I guess if you wanted though, you could carry tape, wd40, water, oil, screwdrivers, 1/2in ring spanner, jumper cables and some rags.
Or you could be like some people on here and carry essentially a whole engine less the block with you! :lol:
PostPosted: Wed Jan 11, 2012 5:14 pm
Bugger
Don"t have a spare motor :D
Wounder if Dr mini will fit in the boot :)
PostPosted: Wed Jan 11, 2012 5:18 pm
I carry:
Fence wire
WD40
several rolls of electrical tape and gaffer tape
1/4" Socket set
spanner set in roll up bag
spare crank sensor
spare o2 sensor
gasket maker
rover SPI fuel trap
2mtrs of vacuum tube and a couple of elbow connectors
The little retaining clip that goes to the temp fan switch in the radiator
couple of spare wheel nuts
jack
leatherman
small inspection mirror
NRMA card
water
Oil
SPI ECU (only if i am really paranoid)
Jump starter
The boot is pretty much full all the time.
PostPosted: Wed Jan 11, 2012 5:22 pm
WOW ! :o
PostPosted: Wed Jan 11, 2012 6:55 pm
WD40 & Duct Tape
IF something moves that shouldn't... Duct Tape
If something doesn't move that should... WD40
:wink: :)
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Wed Jan 11, 2012 7:13 pm
set of short Indian OE spanners
pliers
longnose pliers
multigrips
2 shifters- 4" and 6"
couple of screwdrivers
4 way wheel brace
6 cable ties various sizes
WD40
feeler gauges
Mini jack
4 new sparkplugs
socket set (old small Sidchrome one)
PostPosted: Wed Jan 11, 2012 9:44 pm
I carry pretty much the same as Doc , as well as some electrical wire , joiners and crimpers , a spare set of points , even have an old 12 volt soldering iron, :shock: a new set of plugs , a set of standard wheel nuts because i have mag wheels , but a standard rim for a spare , plus some other bits and pieces that all fits into a small
tackle box .
PostPosted: Thu Jan 12, 2012 5:07 am
DA9jeff wrote:
WD40 & Duct Tape
:wink: :)
:lol: :lol: :lol:
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Thu Jan 12, 2012 12:02 pm
I didnt carry anything in my boot.
Sods law states that no matter how much you carry the thing that breaks will be the one thing you didn't have the parts for.
Simplify and add lightness
Users browsing this forum: drmini in aust and 316 guests
