It is currently Wed Aug 13, 2025 8:11 pm
 Post subject: Trottle Cable Length
PostPosted: Fri Jan 13, 2012 9:27 am
Does someone have a brand new mini throttle cable in their stash , that they could measure the outer and inner cable length for me ?
I'm led to believe that there are 2 different length cables that you can get ,
I E ; standard length , and an extended length .
Reason i ask is i'm thinking about changing my cable , ( which has been in the car , 18 yrs :shock: ) and i have spotted a Teflon Lined cable that suits a go - kart .
Can't see why it wouldn't work . Cheap too !
Thanks , Colin .
PostPosted: Fri Jan 13, 2012 3:12 pm
I ended up with a short one which meant I had to leave off the new accelerator pedal stop and the old one for that matter. :?
PostPosted: Fri Jan 13, 2012 3:57 pm
I have a new one here that I got from a Mini shop a while back, the outer is 66cm long, the inner is 88cm long. It has a couple of part number stickers on it...
QTC4006
MTC309
AYA2179 (this is actually the Australian Morris 1100 part number, the Australian part number for the Mini is AYA2134)
PostPosted: Fri Jan 13, 2012 4:46 pm
Mods rock!
Hi Goodie,
The long one is 750 / 900 mm.
Cheers mate :)
PostPosted: Fri Jan 13, 2012 9:08 pm
Thanks very much for that people , very helpful , i didn't want to have to pull mine out just to measure it , and then have to put it back in again until i got a new one .
PostPosted: Fri Jan 13, 2012 9:10 pm
Measure the outer with a bit of string or wool. :wink:
PostPosted: Fri Jan 13, 2012 9:17 pm
Yeah Morris , not a bad idea .
Users browsing this forum: watsupskip and 205 guests
