It is currently Thu Aug 21, 2025 5:02 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 303, 304, 305, 306, 307, 308, 309 ... 568  Next
PostPosted: Thu Jan 12, 2012 7:48 pm
miniDave wrote:
Nice warm weather so painted the "Skippy" Moke project. Colour is a 2003 Falcon GT colour called 'Citric Acid'.
Wow! That is a great looking Moke. :D
PostPosted: Thu Jan 12, 2012 8:45 pm
Top job :P , reminds me of Spiro da Moke (Mini Mad's)-is that a whole new floor?
PostPosted: Thu Jan 12, 2012 9:44 pm
Spent the morning with GR who ground a cam for me....so interesting to see the process happen in front me. Looked so easy , but sure it's not! Well maybe after you've done it thousands of times.....
Also caught up with Dr mini at GRs and bartered some goodies.
Then went to Miniclassic to get my SCCR gbox underway.
Great morning hangin with helpful , enthusiastic people!
Now with 2 extra ports!
PostPosted: Thu Jan 12, 2012 9:50 pm
A bit more fiddling with the Morris 1100 today, it is now almost happy to putt around town quietly in 4th gear without jumping and shaking!
PostPosted: Fri Jan 13, 2012 12:33 pm
Fitted a Lucas Battery..... Well the sticker at least! :?
PostPosted: Fri Jan 13, 2012 8:24 pm
Replaced the boot seal with a more squishy one and then refitted the boot to the car
Hope to fit the bonnet tomorrow
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Fri Jan 13, 2012 8:28 pm
Had a visit from a compulsive Cooper S restorer, he left empty handed.
I seem to think he was more impressed with the Montego.
PostPosted: Sat Jan 14, 2012 1:15 pm
Got the wife's 1412 stroker nearly ready to lift out... :P
No hurry, I'll finish it tomorrow.. :wink:
Then I have a bit of underbonnet paint touchup to do, and my 1360 will go back in during the week. More HP, noise and rpm.
What, me a hoon? At my age?? :P :twisted:
PostPosted: Sat Jan 14, 2012 5:09 pm
Slap some P plates on for the enhanced hoon effect.
Spent the past 6 hours fitting hilos and adjusting them.
They are a damn pain to adjust.
PostPosted: Sat Jan 14, 2012 5:10 pm
Pulled out all the carpet and underlay and hit the rust on the floor with the angle grinder and wire wheel. Then painted the floor in rust kill.
There's a rust repair needed at a later stage but I will have to leave that till I sort out a welder
PostPosted: Sat Jan 14, 2012 5:17 pm
drilled out some Spot Welds........
Dicko
PostPosted: Sat Jan 14, 2012 7:43 pm
Pulled the dizzy, cleaned and readjusted the points, reset with the timing light. Gee it goes a bit better now that the points are back to 0.016" gap (they had closed up to 0.008")
PostPosted: Sat Jan 14, 2012 8:16 pm
Fitted the wiper motor and washers and then connected them all up
Next I fitted some extra stabilizer mounts between the gearbox and subframe
Maybe fit the bonnet tomorrow
:shock:
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Sat Jan 14, 2012 11:17 pm
Besides building a mini raft I thought I had better start on the door rubbers and paint the edge thing that clamp on the door frame green. Like they were originally.
PostPosted: Sun Jan 15, 2012 12:14 am
Installed new RH window regulator (PO tried to install the left hand one -__-) Fixed the doors inside and out, as well as the locks. Remove the boot for painting and undercoated the bonnet. Eliminated some more rust, filled some dings, getting there :)
1978 Leyland Clubman
