It is currently Tue Jul 29, 2025 3:03 pm
PostPosted: Mon Jan 16, 2012 2:36 pm
I pulled up my carpet to attack some surface rust on the floors and also pulled up the vinyl(?) sound proofing (?) that is stuck to the floor in the front and rear (which incidentally was harboring some more nice surface rust.
Now that I have done that I see there are the 4 or so standard holes in the front footwells. I am planning on recarpeting it all but wanted to know what everyone else does with these holes.
So do I leave them or am I supposed to plug them? Havent seen what others have done on here.
PostPosted: Mon Jan 16, 2012 2:38 pm
I just bought some rubber plugs, though the original may have been plastic.
PostPosted: Mon Jan 16, 2012 2:43 pm
Where did you get them if you dont mind me asking. Save me having to look around
PostPosted: Mon Jan 16, 2012 2:50 pm
Probably just Clark Rubber or the likes.
From memory I went round the whole car and measured any hole without a plug and tool a list with me.
PostPosted: Mon Jan 16, 2012 2:52 pm
Supercrap have grommets too
On the little spinny rack with the bolts and the like
You're so square
Baby I don't care
PostPosted: Mon Jan 16, 2012 3:01 pm
Great, thanks guys
PostPosted: Tue Jan 17, 2012 5:47 pm
Yes, I was going to say Clarke Rubber as well. If you leave them out and hit a flooded road the car will fill up. If the car fills up from some other means then you can take the grommets out to drain it.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Tue Jan 17, 2012 7:38 pm
In the Moke, there's no carpet and the holes get dirt and crap forced into them. I put rubber grommets in but they kept getting kicked out so I fitted a couple of those screw in plugs you used to be able to get for blanking antenna holes, they worked a treat.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Tue Jan 24, 2012 1:22 pm
Thanks all, picked some up from Clarke Rubber on the weekend and they went in a treat.
If only they made ones big enough for some of the holes im going to need to patch up from Good ol Mr Rust
Users browsing this forum: fuzzy-hair-man and 108 guests
