It is currently Tue Aug 19, 2025 6:20 am
 Post subject: dash not working
PostPosted: Tue Jan 17, 2012 4:21 pm
hi guys just a newb question , since having my car i dont have any light in my dash , trying change the bulb but doesnt work is it worth change the printer circuit or just try find a whole replacement , by the way the signal lights work but :?
PostPosted: Tue Jan 17, 2012 4:26 pm
If you can't get the back lights in the dash to work the first thing to look at is the dash light switch.
PostPosted: Tue Jan 17, 2012 4:53 pm
theres a dash light switch ? i just though when u turn the head light switch on it will automatic switch on , or was that what u were talking bout
PostPosted: Tue Jan 17, 2012 4:57 pm
There is a separate switch. It is under the dash on a clubby. A round knob that you twist.
PostPosted: Tue Jan 17, 2012 4:59 pm
I found in my clubby to make sure the actual wiring loom plug is fully plugged in and clicked in place. If the circuit board is crappy you should change it as it will likely just cause issues down the track. If there is custom wiring by previous owners then it takes a bit of investigation
PostPosted: Tue Jan 17, 2012 5:03 pm
Some clubbys also have a seperate fuse for the dash lights which is usually hidden in the engine bay up under where the drivers wiper is.
 Post subject: Printed Circuit.
PostPosted: Tue Jan 17, 2012 6:11 pm
I have NEW printed circuits if you need any.
"Let us remove your "SHORTS"
PostPosted: Wed Jan 18, 2012 1:02 am
so the signals work... do any others work? ALT light? or your highbeams light? above the fuel and temp?
Like the other's said check your light switch.. it is a round know you twist.. normally just right of the ignition, it adjusts the brightness of the lights on the dash... fiddle around with that to see if they come on.
otherwise you will have to check if you are getting power to your dash for the lights...
it's the red and white wire that goes into the connector plug (yeh?)
PostPosted: Wed Jan 18, 2012 1:48 am
My money is on the light switch
It should be under the dash rail, to the right
Gotta turn it, mine turns one way for full, the other for off; If you go far enough in the off direction, it clicks and they on full brightness for some reason - Lucas.
You're so square
Baby I don't care
Users browsing this forum: Majestic-12 [Bot] and 93 guests
