It is currently Sat Jul 19, 2025 12:44 pm
PostPosted: Sat Jan 21, 2012 12:40 pm
Will I feel a huge difference going down to 10'' wheels? Will my top speed change significantly?
PostPosted: Sat Jan 21, 2012 12:44 pm
The difference is in width chage, not diameter.
A narrower tyre will have less wind resistance than a fat one, which will make up for the smaller rolling diameter of the 10, so end result is any top speed difference will be negligable.
Acceleration and braking on the other hand will be improved.
PostPosted: Sat Jan 21, 2012 2:11 pm
most of the 13" 175x50 tyres are slightly taller overall than the 10s... but it`s usually only a pinch, so yes you`ll probably notice it a tad, but yeah just a tad
the big benefit will be the suspension response & handling (feeL)
& then there`s the best bit <what i call> the "Flingability" :-)
PostPosted: Sat Jan 21, 2012 2:31 pm
God I hope they don't look bad inside my arches... it's now my only worry..
PostPosted: Sat Jan 21, 2012 8:01 pm
Mike
A set of 10x6 should fill those arches nicely
PostPosted: Sun Jan 22, 2012 9:44 am
Put your tyre sizes into the calculator to get your rolling diameter:
http://www.ausmini.com/forums/viewtopic.php?t=12115
Your top speed will probably drop about 2mph
Users browsing this forum: Bing [Bot] and 72 guests
