It is currently Fri Jul 25, 2025 10:34 am
 Post subject: lost door key
PostPosted: Mon Jan 23, 2012 1:23 pm
hi guys,
anyone in sydney got spare door keys for a 65 mini deluxe? i know theyre only a few types, i have spare ignition but no door and door is locked. This or any other suggestion on how to solve my problem would be appreciated.
cheers steve
PostPosted: Mon Jan 23, 2012 1:54 pm
The last thread like this ended when it was discovered the car wasn't actually locked.....are you sure?
:lol:
PostPosted: Mon Jan 23, 2012 2:13 pm
Hi Steve, There are a large number of key combinations, hundreds but not thousands like new cars, but you may get lucky.
Your best bet maybe to try and open the qtr vent window.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jan 23, 2012 2:21 pm
thanks mate, im in the car i just need a key for the drivers door, and cant bring myself to pay a locksmith.
PostPosted: Mon Jan 23, 2012 2:54 pm
Drive over to Mini King at Narellan and try all his keys- he has a whole bunch. 8)
PostPosted: Mon Jan 23, 2012 3:49 pm
There`s actually only about 50 or 60,,, i`ll count them one day
My dad has the factory key board with every key meant to fit a mini & their corresponding number
sorry but the only way to find the right door key is to try them all one at a time
ign switches tho, often have the number stamped into the barrell assy
John @ miniking would be my suggestion also, or a locksmith
PostPosted: Mon Jan 23, 2012 4:02 pm
Talk to Mini King.
When you do get it unlocked it might be a good idea to get all the locks keyed the same so you only have one key for all the locks just like when it was new.
PostPosted: Mon Jan 23, 2012 4:14 pm
I got a 67 :?
Carpe Diem
1967 Deluxe (Bluey)
PostPosted: Mon Jan 23, 2012 4:22 pm
cheers for the help guys. ill call john in the morning, then pay him a visit.
PostPosted: Mon Jan 23, 2012 4:23 pm
it`s still 3 of the same
PostPosted: Mon Jan 23, 2012 6:43 pm
MinisPlus
All mini door lock barrels that I have seen have a number stamped into them.
For a door add FS in front ie FS123 and and locksmith can cut a key to the code.
To find the code you need to remove the barrel from the handle or housing, its fairly simple to do. On very worn locks the number can be faint, but a carefull clean should make it legible.
Clubmans had the same key number for both doors, every mini I've seen has a different boot key number from new. The number is on the barrel for a boot lock also. Again you need to remove the barrel from the handle to find it.
Hope this helps,
Ben
How can it be rusty when it's covered in so much oil?
PostPosted: Mon Jan 23, 2012 6:46 pm
Hope this helps,
Ben
I had a Mini Deluxe/K/Cooper S RH door handle.
It was locked.
There seems no way to access the barrel without unlocking it first, as the lock pin gets in the way of removing the escutcheon.
So I took it to Mini King and found a key.. 8)
PostPosted: Mon Jan 23, 2012 7:45 pm
They are often so worn that many keys will open them. Insert a key and put a little bit of load in the barrel by rotating it slightly (in the correct direction to unlock it) then saw the key backwards and forwards a few times and it will probably unlock.
If you have a few keys, you can take the barrel out and see which key does the best job of retracting the tumblers, then file off the ends of any tumblers that still protrude. The lock will be slightly less secure, but lets face it, if a car thief is serious about getting into a deluxe, the lock will only slow him down by a few seconds.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
