It is currently Sat Jul 26, 2025 10:34 pm
 Post subject: fuel line front to rear
PostPosted: Mon Jan 23, 2012 6:26 pm
What would be best type of fuel line to use for replacing the fuel line from front to rear on a mini .
I need to replace the fuel line from 1/4 inch to 5/8 inch and also run a return line to the tank.
Would copper tubing work ?
How much tubing would I need to do it?
Just cause it says it is for a mini ,doesn't mean it will fit a mini......
PostPosted: Mon Jan 23, 2012 6:51 pm
1. Do not use copper for fuel or brake lines, it work hardens with age and vibration, then cracks.
2. Surely you mean 5/16", not 5/8"... :shock:
3. I bought 4M of aluminium coated? steel tube off a roll at Robbos Spare parts years ago, I dunno who has it now. It bent pretty easy. Try someone with brains, like not Supercrap...
PostPosted: Mon Jan 23, 2012 7:16 pm
Is it called "bundy tubing" different to what doc said but it is good for fuel.
PostPosted: Mon Jan 23, 2012 7:53 pm
yeah i normally use Bundy tube & then use a sheath of fuel hose over the top of that,,, keeping both ends outside each front & rear fire walls,,, that way even if somehow the bundy tube cracks/snaps/tears the fuel still can`t get into the cabin
Repco sell rolls of the tube & rolls of fuel hose
PostPosted: Tue Jan 24, 2012 6:33 am
stainless tube 304 annealed tube a few doillars a mrt, can be bent by hand too
