It is currently Wed Aug 06, 2025 6:41 pm
 Post subject: clubman dashboard
PostPosted: Mon Jan 16, 2012 7:30 pm
Can anyone tell me where to find a aftermarket dashboard that has the 3 instrument cluster holes, glove box, cd player holes etc. I would prefer carbonfibre look or vynal look. The only place I can find in aus is minisport and not really what im chasing.
Cheers Mike
PostPosted: Mon Jan 16, 2012 9:24 pm
Make your own :wink:
1977 LEYLAND MINI SUNSHINE 'S'
PostPosted: Mon Jan 16, 2012 10:18 pm
Hi Mike, like ministar says, make your own. I personally don`t like any of the off the shelf dashboards so am making my own. Takes a bit of time but worth it in the end.
Jethro
PostPosted: Mon Jan 16, 2012 11:21 pm
Very true. Just finished mine and made my own glove box and cut a head unit slot etc. Pretty simple to do and the finished product is just how you like it!
PostPosted: Tue Jan 17, 2012 12:25 pm
I bought a second hand one which i like but I also downloaded the plans off the net to make your own. PM me if you would like me to email them to you
PostPosted: Tue Jan 17, 2012 12:29 pm
How do you do it? Cut some plywood, cover in vinyl and bolt/glue in?
'77 Leyland Mini Van
Yep!
You're so square
Baby I don't care
PostPosted: Tue Jan 17, 2012 12:40 pm
Yay! So many ideas, so little time :(
PostPosted: Tue Jan 17, 2012 2:43 pm
Use 3mm aluminium & a bi-metal holesaw.
Either leave naked or foam padded [6-10mm] & vinyl/black leather for an up market look.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Thu Jan 26, 2012 9:32 am
Quick thread hijack, how do you guys mount them? Ive cut a dash out of 9mm ply and haven't been able to work it out... Can you purchase brackets?
PostPosted: Thu Jan 26, 2012 11:33 am
I used right angle brackets and bent them decreasing the angle until they fit comfortably. You can screw them to the dash and then to the dash rails. If you have a globe box it is easy to open it and reach around to screw the dash on. Screw the brackets to the dash before you cover it vinyl (or whatever you choose) so the screw heads are hidden. You can also use screw caps and press them onto the screw heads to make a neater job of it. This is just one of many ways.
PostPosted: Thu Jan 26, 2012 1:20 pm
http://www.minispares.com/Shop.aspx?ty= ... ior%7eDash
http://www.minisport.com/mini-spare-par ... _Mini.html
Some of those you may need to cut a cd player hole.
If you were wanting a carbon fibre one:
http://www.minispares-online.co.uk/?cat ... od_id=1515
Cheers Brenton
Users browsing this forum: No registered users and 62 guests
