It is currently Sun Aug 10, 2025 7:45 am
PostPosted: Sun Jan 29, 2012 4:41 pm
I need a K&N Filter for my 1.5" SU
Where can I get one in sydney?
Or, is there a better filter I can get for an 1.5" SU?
You're so square
Baby I don't care
PostPosted: Sun Jan 29, 2012 5:38 pm
Adam,
Read this article by Keith Calver and then tell me you still want one.
Bottom line- a std HS4 donut filter with a few holes added to the case outperforms a K&N on the dyno. :wink:
http://www.minimania.com/web/SCatagory/ ... ticleV.cfm
PostPosted: Sun Jan 29, 2012 5:41 pm
Adam,
He might not want to drive on a dyno. :mrgreen:
Which is better on the road? Filter efficiency?
PostPosted: Sun Jan 29, 2012 5:42 pm
Probably the donut filter does better- if you MUST have a K&N, I'd fit their replacement element into the stock case.
Best of both worlds then.
IMO the conical K&N is too small (for bigger motors anyhow). Not enough area...
PostPosted: Sun Jan 29, 2012 5:47 pm
I always worry about the lack of surface area in a lot of filters, even some of the paper filters are not made properly and only a small part of the paper is actually being used.
PostPosted: Sun Jan 29, 2012 6:00 pm
Standard donut filter with some holes in it sounds good to me then!
Will dig out the old filter housing tomorrow.
thanks gentlemen
You're so square
Baby I don't care
PostPosted: Sun Jan 29, 2012 8:15 pm
Unfortunately there are no "stock" filter cases for twin 1.5s. I (or rather the local dyno) found 2hp when we replaced my home made case (2 flat panels sandwiching a pair of XU1 paper filters) with a pair of K&N cones.
I haven't done the maths but I would suggest any concerns do not involve issues of filter area.
Cheers, Ian
