It is currently Wed Jul 23, 2025 12:15 pm
 Post subject: bad lean
PostPosted: Sat Apr 23, 2005 2:38 pm
my car is sitting way to high on the passenger side, the camber is bad because of this is there a way to fix this problem without spending much money??
Potato
 Post subject: Re: bad lean
PostPosted: Sat Apr 23, 2005 2:54 pm
Is it a Hydrolastic or rubber cone suspension type vehicle :?:
If hydro...then you can just pump up the side thats ...well...down :idea:
PostPosted: Sat Apr 23, 2005 3:28 pm
na its rubber cone, i have barley any money to spend on it, only 50 bucks richer at the moment, anything i can do?
Potato
PostPosted: Sat Apr 23, 2005 4:10 pm
It will most probably be one or both knuckle joints. $15 each but you'll need a rubber donut compressor.
PostPosted: Sat Apr 23, 2005 5:09 pm
...and hope that there are still threads inside the donut for the puller to screw into.. :evil:
