It is currently Fri Jul 18, 2025 10:24 pm
PostPosted: Fri Feb 10, 2012 7:29 pm
Been on the run around today trying to find some Loctite 515 for the gearbox to block gasket (as suggested).
Can only find a 50 ml tube of 518 for $42.:shock:
So what is the finite difference between 510, 515 and 518?
Cheers -
Dave K.
PostPosted: Fri Feb 10, 2012 8:03 pm
Dunno what 510 is (or the finite difference), but you can use 518 as you would 515!
Steve
PostPosted: Fri Feb 10, 2012 8:28 pm
http://au.iloctite.com/en/loctite-574-5 ... -gasketing
Any would do.:wink:
yeah I use 518 if I can't get 515. But I have a whole cartridge full of 515.. :shock: :P
PostPosted: Tue Feb 14, 2012 5:44 pm
Got a 50ml tube of 515 off the racks at Blackwoods. $24.95 including GST.
Hopefully 50 ml will do what is required for one engine?
Dave K.
PostPosted: Tue Feb 14, 2012 6:13 pm
Should do a couple of engines Dave. :wink:
Put it on thin- you only need a smear.
Users browsing this forum: No registered users and 23 guests
