It is currently Fri Aug 01, 2025 10:12 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Feb 19, 2012 8:16 pm
Hanra wrote:
It was only sprayed on the metal contact area. It wasn't soaked in it.
Deoxit wrote:
Even when a treated connector mates with an untreated one DeoxIT will migrate and coat the other! When connectors are separated, DeoxIT will recoat the exposed metal surfaces to prevent oxidisation whilst apart.
It moves! (freaky) :shock:
PostPosted: Sun Feb 19, 2012 9:10 pm
Yeah. From the definition for DeOxit D5 (here: http://www.techtronics.com.au/p/116538/details.asp ) it sounds like this leaves a coating of oil or similar to prevent oxidation without causing any resistivity. That's fine for low voltage applications, but I'm tipping its caused the breakover as it migrated. The rotor button material soaks this stuff up.
PostPosted: Sun Feb 19, 2012 10:13 pm
Maybe if you had a MINI in your garage it would be more inclined to come home...
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Mon Feb 20, 2012 7:38 am
I've already got one BMW. So that disproves that idea.
PostPosted: Mon Feb 20, 2012 6:21 pm
drive it more hanra hahahaha, in the first place, there not going to melt when you take them out only joking
Sorry to hear the bad news with your car, its pisses me off to when shite like this happens, simply things shouldnt be so hard,
Push it bck in shed have a few beers wait a few weeks and then open shed door all will be better when you se it there
PostPosted: Mon Feb 20, 2012 10:14 pm
Yep... Back in the shed.... POS....
PostPosted: Tue Feb 21, 2012 7:30 am
You could always put a Nissan Pulsar dizzy (are Hitachi not Lucas) in it, then you will have reliability.
It's not as if your car is original or anything.. :lol:
PostPosted: Tue Feb 21, 2012 8:14 am
Poor little lonely car.
Where's it's bubble, man?
PostPosted: Tue Feb 21, 2012 8:28 am
I know, that would be the smart thing to do... But Ive just spent $110 getting this dizzy repaired after it broke an advance weight spring... then Ive just bought a new Pertronix for it for $100.... Cap, rotor button.... All just monies wasted then...
And the bubble... On Sunday when I took it for a test drive, as I drove off the base mat, it caught on the underside of the car and ripped the zip off the base mat and broke the zip in half... $1090 for a new bubble as the base mate is not available separately..... Im going to take the mat into a canvas shop to see if it can be repaired... I have not had a good run with this car of late... Very much over it. Very.....
PostPosted: Tue Feb 21, 2012 12:29 pm
Well, how would you feel if your loved one turned their attention to a big black.............
car
PostPosted: Tue Feb 21, 2012 12:33 pm
:shock: :D :D :D :D :D :D
PostPosted: Tue Feb 21, 2012 1:23 pm
:lol: Ha ha, the Torana has both length AND girth..
What chance does the little mini have? Technique?
PostPosted: Tue Feb 21, 2012 2:25 pm
Can always park a Mini in tighter spaces... :wink:
PostPosted: Tue Feb 21, 2012 7:49 pm
Just send me the car Brad, my standing offer still applies :)
It can sit in the shed with my moke that had the exact same symptoms of new ignition parts and still blushing and farting every time I try to take it for a drive :evil: The moke was so bad I took the whole engine out, head off, clutch off and there it has sat. That'll learn it!
PostPosted: Sat Feb 25, 2012 8:56 am
I found this quote while surfing distributors. It comes from the Accuspark retailer on eBay. I suppose there's a lot of marketing involved in getting a no-name rotor bought over eBay, but it offers some background I suppose.
Accuspark wrote:
Recently manufactured rotor arms have been failing because the typical "mix" used in the injection moulding nowadays contains more carbon blacking and is therefore more conductive. Still more importantly, the rivet which holds the brass inlay into the moulding is slightly longer than the original, bringing it too close to the spring clip on the underside. The high tension current, averaging 30,000 volts, is always looking for the easiest route to earth and shorts out from the tip of the overlength rivet, through the reduced thickness of more conductive plastic and the spring clip on the underside of the rotor arm, to earth out down the distributor shaft. Result - no sparks at the plugs. The situation sometimes rectifies itself on cooling, but then reoccurs with increasing frequency until the rotor permanently short circuits.
Modelled on the original, dependable 1960’s design, but made from modern materials on the latest machinery to very close tolerances.
These LUCAS STYLE RED ROTOR ARMS will not let you down.
The integrally moulded brass inlay dispenses with the troublesome rivet used on most versions which is known to short circuit.
The increased insulation properties of the body makes them suitable for use with high voltage coils & electronic ignition kits.
The spring steel clip on the underside, in conjunction with a revised internal tolerance assures a really snug fit, even on old & slightly reduced diameter mountings.
