It is currently Mon Jul 28, 2025 10:21 am
 Post subject: breathers
PostPosted: Thu Feb 23, 2012 7:15 pm
how many breathers should i run on an 1100s engine?
PostPosted: Thu Feb 23, 2012 7:17 pm
factory was 1, I use two
PostPosted: Thu Feb 23, 2012 7:20 pm
I use 1.
PostPosted: Thu Feb 23, 2012 7:27 pm
I use 1, from the rocker cover to a Toyota PCV valve into the manifold, on both my 1360 and 1412 stroker.
I had it on the flywheel housing instead, but the drop gears tossed oil up it on long LH bends if I had `a few' revs up.
A well known Nc Mini racer we all know uses none.
IMO you only need more than 1 decent breather if you have poor ring sealing. :wink:
On my 1360 (now back in the car) I have since added a hose from the rocker cover to the drop gear housing- to help equalize pressure upstairs/downstairs.
Last edited by drmini in aust on Fri Feb 24, 2012 1:52 pm, edited 1 time in total.
PostPosted: Thu Feb 23, 2012 7:33 pm
im using an electric fuel pump so i was wondering if i could put a blanking plate where the mechanical fuel pump goes with a fitting in it to go to a catch can and plum a the rocker cover breather in to it
PostPosted: Thu Feb 23, 2012 7:34 pm
simon k where abouts do you have the pair of breathers
PostPosted: Thu Feb 23, 2012 7:38 pm
Been there done that. :evil:
At 4500 rpm and above the crank and rods will tos HEAPS of oil up it.
Don't bother. (MiniMania in USA sells a baffled one, it might work but it ain't cheap).
PostPosted: Fri Feb 24, 2012 5:33 am
http://www.ausmini.com/forums/viewtopic.php?t=71363&postdays=0&postorder=asc&start=15
PostPosted: Fri Feb 24, 2012 9:36 am
one on the flywheel housing and one on the rocker cover...
can see them here - two into one, then into a little inline PCV and into the inlet manifold
PostPosted: Fri Feb 24, 2012 1:27 pm
3..... clutch cover/tappet cover/back "door"of block into a 2lt catch can[with drain tap on the bottom.]Starting at the rear offtake...tappet offtake...clutch housing...to catch can on RHS inner guard panel. 1 hose with 3 "T" pieces.
1974 1150cc Leyland Mini S racer,
1975 No motor Leyland Mini "ute"
1991 IPRA Honda Integra (in the build)
1995 Land Rover Discovery 300Tdi
CAMS Scrutineer
PostPosted: Fri Feb 24, 2012 1:54 pm
Sorry, :oops: double post...
Last edited by drmini in aust on Fri Feb 24, 2012 5:32 pm, edited 1 time in total.
PostPosted: Fri Feb 24, 2012 4:15 pm
[A well known Nc Mini racer we all know uses none].
I don't like catch tanks on road cars, they make the cabin smelly. But yeah if it was a racer I'd use one.
Nice work on quoting your own post. That's awesome.
Cheers, Matt
Don't be fooled, Gruhms is not my real name.
PostPosted: Fri Feb 24, 2012 5:30 pm
Sorry double post and I didn't catch it. Had to go in a hurry... :?
Thanks for posting it all again though, pics and all... :lol:
PostPosted: Fri Feb 24, 2012 6:06 pm
I have a single breather, basically the same setup as the good Doctor's. Seems to work well enough. :)
PostPosted: Sat Feb 25, 2012 9:10 am
Happy to be of service.
I'll stop wasting this thread now.
Cheers, Matt
Users browsing this forum: Phil 850 and 83 guests
