It is currently Wed Jul 23, 2025 12:22 pm
 Post subject: flicking rev meter
PostPosted: Sun Apr 24, 2005 11:39 am
hello all just a small question on my autometer rev gage???
when i rev it up too 6000 to 7000 the gage needle sometimes sticks and flicks like its getting stuck.
its an all electric gage running straight from the coil...any idears???
maybe this is a sign of the coil on the way out...or just a wirering problem...
come to think of it it does it when i rev it to anything....but just not all the time.
PostPosted: Sun Apr 24, 2005 12:08 pm
By chance have you installed a Palsur dizzy
PostPosted: Sun Apr 24, 2005 12:58 pm
nope..its all mini....aparently it did it last week when i did my 160kph run as my girl freind who was in the car said my rev counter was going nuts???
PostPosted: Sun Apr 24, 2005 3:03 pm
check your earth :lol:
PostPosted: Sun Apr 24, 2005 3:28 pm
earth on the gage or on the coil????
PostPosted: Sun Apr 24, 2005 3:38 pm
gauge earth
PostPosted: Sun Apr 24, 2005 3:46 pm
ok will do this asap.thanks...will post up reply if this dosent work
PostPosted: Sun Apr 24, 2005 4:13 pm
why what would that do?
PostPosted: Sun Apr 24, 2005 6:14 pm
Check all connections from tacho to the coil and earth, if loose tacho will jump about.
Question re the Pulsar dizzy- some older tachos don't like electronic ignition. Autometer should be OK though. :wink:
PostPosted: Sun Apr 24, 2005 6:33 pm
Mini points don't like high revs and the tacho could be telling you this!
 Post subject: Autometer
PostPosted: Sun Apr 24, 2005 7:54 pm
be honest now...has the instrument ever had a hard knock :?: or been dropped on a hard surface :?:
Could be the meter itself...nothing to do with the pulses feeding it :!: :idea:
PostPosted: Sun Apr 24, 2005 9:36 pm
no hard knocks ....i treat thoses gages like a gold nuget as they cost me a s...t load
will ask link automotive about the points....as they havent been changed for a long time...would say two years or so.
 Post subject: OK
PostPosted: Sun Apr 24, 2005 9:44 pm
OK.....Change the points for some good NGKs and make sure you clean off the surfaces first with Metho...two years is quite long enough with conventional ignition... :roll:
