Convertible Mini wrote:
If it is your ignition circuit fuse that is blowing (Which should be 35 Amp) there should be a whole bunch of Green wires on one side of it. Disconnect them all and try re connecting them one by one with the Key on. Which ever wire blows the fuse leave off and then check what does not work from that circuit which will obviously be what works off that wire that you left disconnected. Then check that circuit through for the possible location of the short. Always start at the power source starts and work your way back. One most common fault..... Make sure the wiper arms have not been removed and placed back when the motor was not at park position .
Thanks Tony, that reminded me of a problem with the van and your advice solved it. Was the reverse light. Now to figure out how to wire it up properly. Or i could throw it in the bin.
