It is currently Sat Jul 19, 2025 12:40 pm
 Post subject: a little bolt help :)
PostPosted: Tue Feb 28, 2012 8:55 am
Hi lads
bit of a silly one, im missing the rear bolts that hold the drum upto the hub
http://www.minispares.com/Product.aspx?ty=pb&pid=36738
can anyone tell me what bolt and length i need to ask for at the bolt shop?
my drums are stepped drums so do i need a particular bolt for that??
PostPosted: Tue Feb 28, 2012 9:03 am
Thread is 1/4 UNF, with csk head but not sure what length, I don't have one handy.
[edit] watch people in Mini shops don't try and sell you M6 ones, I had that happen once. They do screw in (sort-of) but are loose. NBG..... :x
Last edited by drmini in aust on Tue Feb 28, 2012 9:22 am, edited 1 time in total.
PostPosted: Tue Feb 28, 2012 9:16 am
Inch and a half long I think.
The ones on my car are socket heads, I always found the phillips head ones annoying to get off.
PostPosted: Tue Feb 28, 2012 9:30 am
im tapping into a some alloy hubs so a M6 would be ok and more common
PostPosted: Tue Feb 28, 2012 9:33 am
If you can get the 1/4 inch ones you'd be better off as they're the correct size to suit the drum and a finer pitch thread than metric.
PostPosted: Tue Feb 28, 2012 9:38 am
I hate finding metric threads on a Mini... :evil: :x :roll:
It shows people don't know, or don't care.............
PostPosted: Tue Feb 28, 2012 9:41 am
The factory went metric from 1992 onwards for half the car. :lol:
PostPosted: Tue Feb 28, 2012 9:42 am
lol.. yes well these hubs don't have the screw holes for the drums.
i wanted to use something common as im making the car bit light weight.
just wanted to get that bolt in titanium.
PostPosted: Tue Feb 28, 2012 9:47 am
Here's a weight saving tip: leave it off.
If it didn't have holes from new the manufacturer obviously intended there not to be any.
PostPosted: Tue Feb 28, 2012 10:20 am
These little screws do nothing really- most Jap cars have nothing holding their disc rotors on, except the 4 wheel studs/bolts!! :lol:
Hint: if the wheels come off, you have bigger probs to worry about than keeping the drums on.. :P
PostPosted: Tue Feb 28, 2012 12:31 pm
If the drums can come loose, you've got a bigger problem than two 1/4" bolts can solve.
Edit: Oops, I should read the previous messages properly. :oops:
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
I luv your hints Doc :wink:
Should be more of it.. :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Feb 28, 2012 12:44 pm
they wont come loose..
i get the wheels hold it on..
just want it for extra security :)
im going with a Titanium bolt in m6 and lots of anti seize crap as the doc has suggested.
PostPosted: Tue Feb 28, 2012 6:11 pm
Read it again !
NBG is No Blardy Good!! :lol:
Watch people in Mini shops don't try and sell you M6 ones, I had that happen once. They do screw in (sort-of) but are loose. NBG..... :x
:wink:
Sir Alec! we are not worthy!
PostPosted: Tue Feb 28, 2012 6:28 pm
graham in aus wrote:
Read it again !
:wink:
In this case, there are NO threads in the (alloy) hub already, so if Nick wants to tap them 6mm to suit his expensotainium bolts, good luck to him. :lol:
Users browsing this forum: Bing [Bot] and 73 guests
