It is currently Sat Aug 02, 2025 12:58 pm
 Post subject: rear indicator problem
PostPosted: Sun Mar 11, 2012 7:40 pm
so a wayward toolbox sliding round in the boot appears to have sheared off the little metal clip that holds the electrical plug onto my rear indicator light on the rear drivers side!
it can never just be a blown bulb eh?
so, can I easily buy a replacement bulb holder with that clip intact or do I need to replace the whole rear indicator/brake light housing?
and if so either way, any pointers or anyone willing to part with one please for the right hand side?
taaaa
PostPosted: Sun Mar 11, 2012 8:11 pm
have broken mine b4 in a clubman i just wacked a old one in there :)
PostPosted: Mon Mar 12, 2012 3:59 pm
so you reckon it's pretty easy to just replace the bulb holder then?
cheers, I'll suss out some options from repco/supercheap then
PostPosted: Mon Mar 12, 2012 5:57 pm
Those bulb holders are swaged in, I tried to remove one once and gave up.
I'd find another lamp unit, it's easier. :wink:
PostPosted: Mon Mar 12, 2012 6:34 pm
yep, I just spent 20 mins trying to get the bugger off - it just kept spinning and I didn't want to trash it anymore
anyone got a spare right hand rear base they want to part with please?
I'll put it in the wanted page
PostPosted: Mon Mar 12, 2012 6:57 pm
If the lamp holder is still together inside but the spade lug has busted off, I'd try soldering it back on!
If the old lug is buggered, cut a brass one off a spade terminal.
PostPosted: Mon Mar 12, 2012 7:26 pm
I tried the solder option, but it is sheared off right to the plastic unfortunately
I'm thinking my easiest option is to find a replacement
thanks anyways
and by the way, is it just me or everytime I go to reply I get logged out and have to re-log back in multiple times!?!
PostPosted: Mon Mar 12, 2012 7:27 pm
Must be you, I have no problem with posting.
PostPosted: Mon Mar 12, 2012 7:37 pm
so,,, asking the question for the purpose of answering (or attempting to) your wanted add
is it a 2 piece lens / 3screw base?
or
a 1 piece lens/2 screw type?
PostPosted: Tue Mar 13, 2012 4:26 am
it is the two screw base, sorry
thanks
PostPosted: Wed Mar 21, 2012 6:20 pm
oh, and for now, good old gaffer tape once again fixes everything!!
:wink:
Users browsing this forum: No registered users and 72 guests
