It is currently Tue Jul 29, 2025 5:09 am
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon Mar 19, 2012 7:19 pm
I am unhappy with my 7x13 wheels as my bearings are starting to die and i have play in the steering rack a few months after it was fixed..
I would like to run 6x10 wheels but would like to still keep my sport pack arches.. It is a bit of a headache to change them as holes have been drilled in the body and bits of panel have been cut.
Does anyone have pictures of 6x10's with sportpack arches that fit well?
I just want something that will still fill the arch well like the 7x13
I need to do a disc conversion so i can put the 10's on.
This is what it looks like now
PostPosted: Mon Mar 19, 2012 7:24 pm
Get the 10 x 6 Mambas from Midlands wheels, their offset means they stick out and will fill the flares
www.facebook.com/sydneyminis
www.facebook.com/miniowners
www.sydneyminis.com
1969 Morris Mini K- 1380cc for driving
1969 Morris Mini K Panel Van- 1098 for loads
1971 Morris Mini K Panel Van- Still in the barn
2000 Rover Mayfair- Luxury
PostPosted: Mon Mar 19, 2012 7:26 pm
Milatsmadmini
http://www.minisport.com/mini-spare-par ... S2681.html
thats the kit i told ya about...
And hell yeh... them mambas are hot!
Have you got a link by any chance? I was hoping to get the 10" versions of the ones i have now.
PostPosted: Mon Mar 19, 2012 7:29 pm
mattsmadmini wrote:
http://www.minisport.com/mini-spare-parts/info_MS2681.html
Are they easy to fit? I have never done something like that before.. I might just pay someone to do it if its easier.
Whats the stopping power like with the little brakes?
PostPosted: Mon Mar 19, 2012 7:31 pm
Milatsmadmini
http://bit.ly/A1CzRW
PostPosted: Mon Mar 19, 2012 7:32 pm
Milatsmadmini
its easy enough to change over...
PostPosted: Mon Mar 19, 2012 7:38 pm
Not a fan of those...
They say the off set is the same.. Do you think this will fit?
http://www.midlandwheels.com/Shop/P-238 ... acite.html
Do you guys reckon i will need to lower the mini? I have hilos in the back but not the front :/
What are the best every day road tyres?
PostPosted: Mon Mar 19, 2012 8:13 pm
A008's
PostPosted: Mon Mar 19, 2012 8:38 pm
Hi Danny, can I assume you have drum brakes on the front? If so are your front wheel bearings only ball type? Maybe if you change to taper roller type bearings with disk brakes then the bearings will last longer? Also the pommie steering racks are really bad and I have found they only last 18 months to 2 years and that's with 10" wheels, so changing to 10" wheels will not solve your rack problems
I think your car looks great and would be a shame to change to smaller wheels, but that's only my opinion.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 19, 2012 8:41 pm
You do realise going from big fat wheels to small fat wheels won't solve the problem in its entirity?
Lots of the bearing and other issues come from the offset of the wheels, that is the wider the wheels the more leverage being applied to the outer bearing and thats why they wear.
The problem won't be as bad as with the 13s, but eventually the issues may come back to haunt you.
 Post subject: Wheels..?
PostPosted: Mon Mar 19, 2012 8:43 pm
How about these ? http://www.miniownersclub.com.au/index. ... &Itemid=28
"Let us remove your "SHORTS"
PostPosted: Mon Mar 19, 2012 8:48 pm
Did u check how much for replacement bearings & fix up rack play.....
Ur still going to have to convert your discs ... New rims & tyres which in the end might fit your arhes .... Just .... but won't look like they are now.
What then? New arches ??? Paint trim etc etc?
PostPosted: Mon Mar 19, 2012 9:06 pm
Dan as you know I've just done this exact conversion. All my steering issues and displeasures have been fully rectified. Come have a look and a drive of mine and see what you think. You can keep those flares too :)
PostPosted: Mon Mar 19, 2012 9:10 pm
http://www.theminiforum.co.uk/forums/to ... ge__st__30
http://farm4.static.flickr.com/3251/271 ... 88e776.jpg
Users browsing this forum: Bing [Bot] and 18 guests
