Straight cut gears wear their teeth more than helicals do, due to point loading on the teeth.
Mk2 S box had almost the same gears in it as an Oz Mini K 1969-71 or early Oz Clubby, 1971-74.
The exceptions are the 22G1371 1st motion shaft and the 22G1040 cluster/laygear. Swap these in and fit a 3.44 diff and you have Mk2 S ratios. I run 2 of these boxes under a 1360 and a 1412 stroker.
The 22G1371 is getting a bit scarce new now, but you can replace this with a DAM3167. Same gear, except it has an 18mm needle bearing inside instead of 14mm. I can modify your standard mainshaft to suit this bearing.
Mk2 S helical gears are pretty durable for road use unless you go flat shifting. If you want to do that, go buy a Jap car...
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
